API Calling
- What Are the Possible Causes for an API Calling Failure?
 - What Should I Do If an Error Code Is Returned During API Calling?
 - Why Am I Seeing the Error Message "414 Request URI too large" When I Call an API?
 - What Should I Do If "The API does not exist or has not been published in the environment." Is Displayed?
 - Why Am I Seeing the Message "No backend available"?
 - What Are the Possible Causes If the Message "Backend unavailable" or "Backend timeout" Is Displayed?
 - Why Am I Seeing the Message "Backend domain name resolution failed" When a Backend Service Is Called?
 - Why Doesn't Modification of the backend_timeout Parameter Take Effect?
 - How Do I Switch the Environment for API Calling?
 - What Is the Maximum Size of an API Request Package?
 - How Do I Perform App Authentication in iOS System?
 - Why Can't I Create a Header Parameter Named x-auth-token for an API Called Through IAM Authentication?
 - App (Credential) FAQs
 - Can Mobile Apps Call APIs?
 - Can Applications Deployed in a VPC Call APIs?
 - Does APIG Support WebSocket Data Transmission?
 - Does APIG Support Persistent Connections?
 - How Will the Requests for an API with Multiple Backend Policies Be Matched and Executed?
 - Is There a Limit on the Size of the Response to an API Request?
 - How Can I Access Backend Services over Public Networks Through APIG?
   Parent topic: FAQs
