Updated on 2026-10-28 GMT+08:00
Managing Deployment Architectures
After a deployment architecture is created, you can modify, delete, view, copy, and export it. This meets your requirements for architecture design, iterative optimization, information retention, and cross-scenario reuse. Architecture management is more flexible, efficient, and adapts to dynamic changes during software development and O&M.
Modifying a Deployment Architecture
  1. Log in to COC.
  2. In the navigation pane, choose Resilience Center > Architecture Design. The Architecture Design page is displayed.
  3. On the displayed page, locate the target deployment architecture and click Modify in the Operation column.
  4. Modify related parameters as required. For details, see Table 1.
    Figure 1 Modifying a deployment architecture
    Table 1 Basic information parameters
    Architecture Name
    Name of the deployment architecture
    The name must be unique and can contain a maximum of 128 characters, including letters, digits, hyphens (-), underscores (_), and spaces. It cannot start or end with a space.
    Architecture Description
    Description of the deployment architecture.
    Enterprise Project
    Select the enterprise project to which the deployment architecture belongs.
  5. Click OK.
Copying a Deployment Architecture
  1. Log in to COC.
  3. On the displayed page, locate the target deployment architecture and choose More > Copy in the Operation column.
    Figure 2 Copying a deployment architecture
  4. (Optional) Set its parameters to the same as those of the replicated one. You can also adjust them as required. For details, see Table 2.
    Figure 3 Copying a deployment architecture
    Table 2 Basic information parameters
    Architecture Name
    Application
    Select the application to which the architecture belongs.
    After the architecture is created, its associated applications cannot be modified.
    Enterprise Project
  5. Click OK.
Exporting a Deployment Architecture
  1. Log in to COC.
  3. On the displayed page, locate the target deployment architecture and choose More > Export in the Operation column.
  4. In the displayed dialog box, select the format to be exported.
    Figure 4 Exporting a deployment architecture
  5. Click OK. The deployment architecture in the format selected in 4 is automatically exported.
    You can view the exported deployment architecture file on the local PC or share it with related personnel.
Deleting a Deployment Architecture
  1. Log in to COC.
  3. On the displayed page, locate the target deployment architecture and click Delete in the Operation column.
  4. Enter DELETE and click OK.
    The deleted architecture information is no longer displayed in the deployment architecture list.
    Figure 5 Deleting a deployment architecture
