El contenido no se encuentra disponible en el idioma seleccionado. Estamos trabajando continuamente para agregar más idiomas. Gracias por su apoyo.
- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Automated O&M/
Account Management/
Password Change Policies
Enabling the Password Change Policy
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. In the Routine O&M area, click Account Management.
- Click the Change Account Password tab and then the Password Change Policies tab, and set the management policy based on service requirements to ensure that incremental host instances can be automatically managed.
Figure 1 Enabling the password change policy
- To automatically manage incremental host instances that are not bound to components, enable Global Baseline Password Change Policy in By Global. To automatically manage the incremental host instances bound a component, enable Password Change Policy for Component Baseline in Component Baseline Dimension, click Select Component, search for the application or component names, and click OK.
Figure 2 Selecting a desired component
Parent topic: Account Management
