rand
This function is used to return an evenly distributed random number that is greater than or equal to 0 and less than 1.
Syntax
rand(INT seed)
Parameters
| Parameter | Mandatory | Type | Description |
| seed | No | INT | The value can be a float, integer, or string. If this parameter is specified, a stable random number sequence is obtained within the same running environment. |
Return Values
The return value is of the DOUBLE type.
Example Code
The value 0.3668915240363728 is returned.
select rand();
The value 0.25738143505962285 is returned.
select rand(3);
