Updated on 2025-01-09 GMT+08:00
RENAME COLUMN
Function
The ALTER TABLE ... RENAME COLUMN command is used to change the column name.
Precautions
  • If your table is already on the desired protocol version, you need to execute the following statement before the modification can be successful:
    ALTER TABLE table_name SET TBLPROPERTIES ('delta.columnMapping.mode' = 'name');
  • If your table is not on the desired protocol version, you need to execute the following statement before the modification can be successful:
    'delta.columnMapping.mode' = 'name',
    'delta.minReaderVersion' = '2',
    'delta.minWriterVersion' = '5')
Syntax
ALTER TABLE tableName RENAME COLUMN old_columnName TO new_columnName
Parameter Description
Table 1 RENAME COLUMN parameters
tableName
Table name.
old_columnName
Old column name.
new_columnName
New column name.
Required Permissions
  • SQL permissions
Table 2 Permissions required for executing ALTER TABLE
Permission Description
ALTER permission on a table
  • Fine-grained permission: dli:table:alter
  • Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Example
ALTER TABLE table1 RENAME COLUMN addr to address
ALTER TABLE table1 RENAME COLUMN addr.priv to province
a.b.c indicates the full path of a nested column. For details about the nested column rules, see ADD COLUMNS.
Response
You can run the DESCRIBE command to view the new column name.
