DELETE
Function
This command deletes records from a Delta table.
Syntax
DELETE from [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`
[ WHERE boolExpression]
Parameter Description
Parameter |
Description |
database_name |
Name of the database, consisting of letters, numbers, and underscores (_) |
table_name |
Name of the table in the database, consisting of letters, numbers, and underscores (_) |
bucket_name |
OBS bucket name |
tbl_path |
Storage location of the Delta table in the OBS bucket |
boolExpression |
Filter conditions for deleting records |
Required Permissions
- SQL permissions
Permission Description |
DELETE permission on a table |
- Fine-grained permission: dli:table:delete
- Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Examples
delete from delta_table0 where column1 = 'value1'; delete from delta_table0 where column1 IN ('value1', 'value2'); delete from delta.`obs://bucket_name0/db0/delta_table0` where column1 = 'value1';
System Response
You can view the result in driver logs or on the client.
