Help Center/ Cloud Container Engine/ Drawer/ Configuration Reference/ Nodes/ kubelet/ Maximum Number of Processes in a Pod
Updated on 2025-06-13 GMT+08:00
It specifies how many processes can be created in a pod. The default value is -1. The number of processes that can be created in the pod is limited by the PIDs that the pod use.
Value Range
None
Default Value
-1
Modifiable
Yes
Scope
CCE standard and CCE Turbo clusters
Suggestions
Set the parameter to -1.
If this parameter is set to a large value, PIDs that a single pod use will run out.
