Updated on 2025-11-11 GMT+08:00
Maximum Pods Managed by kubelet
It specifies the maximum number of pods managed by kubelet. These pods include the default system pods. This configuration prevents the node from being overloaded.
Value Range
Greater than or equal to 0
Default Value
110
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Configure this parameter based on the node configuration.
