How Do I Use Events to Fix Abnormal Workloads?
If a workload is abnormal, you can first check the pod events to locate the fault and then rectify the fault by referring to Table 1.
Event Information |
Pod Status |
Solution |
PodsScheduling failed |
Pending |
For details, see What Should I Do If Pod Scheduling Fails?. |
PodsFailed to pull image Failed to re-pull image |
FailedPullImage ImagePullBackOff |
For details, see What Should I Do If a Pod Fails to Pull the Image?. |
PodsCreation failed Failed to restart container |
CreateContainerError CrashLoopBackOff |
For details, see What Should I Do If Container Startup Fails?. |
The pod status is Evicted, and the pod keeps being evicted. |
Evicted |
For details, see What Should I Do If a Pod Fails to Be Evicted?. |
The storage volume fails to be mounted to the pod. |
Pending |
For details, see What Should I Do If a Storage Volume Cannot Be Mounted or the Mounting Times Out?. |
The pod stays Creating. |
Creating |
For details, see What Should I Do If a Workload Remains in the Creating State?. |
The pod stays Terminating. |
Terminating |
For details, see What Should I Do If Pods in the Terminating State Cannot Be Deleted?. |
The pod status is Stopped. |
Stopped |
For details, see What Should I Do If a Workload Is Stopped Caused by Pod Deletion?. |
Viewing Pod Events
Run the kubectl describe pod {pod-name} command to view pod events, or log in to the CCE console and view pod events on the workload details page.
$ kubectl describe pod prepare-58bd7bdf9-fthrp ... Events: Type Reason Age From Message ---- ------ ---- ---- ------- Warning FailedScheduling 49s default-scheduler 0/2 nodes are available: 2 Insufficient cpu. Warning FailedScheduling 49s default-scheduler 0/2 nodes are available: 2 Insufficient cpu.
