Help Center> Cloud Container Engine> User Guide (ME-Abu Dhabi Region)> FAQs> Cluster> Cluster Creation> Is Management Scale of a Cluster Related to the Number of Master Nodes?
Updated on 2022-08-09 GMT+08:00
Management scale indicates the maximum number of nodes that can be managed by a cluster. If you select 50 nodes, the cluster can manage a maximum of 50 nodes.
The number of master nodes varies according to the cluster specification, but is not affected by the management scale.
After the multi-master node mode is enabled, three master nodes will be created. If a master node is faulty, the cluster can still be available without affecting service functions.
