Updated on 2024-01-04 GMT+08:00
Overview
CCE supports different types of resource scheduling and task scheduling, improving application performance and overall cluster resource utilization. This section describes the main functions of CPU resource scheduling, GPU/NPU heterogeneous resource scheduling, and Volcano scheduling.
CPU Scheduling
CCE provides CPU policies to allocate complete physical CPU cores to applications, improving application performance and reducing application scheduling latency.
Function
Documentation
CPU policy
When many CPU-intensive pods are running on a node, workloads may be migrated to different CPU cores. Many workloads are not sensitive to this migration and thus work fine without any intervention. For CPU-sensitive applications, you can use the CPU policy provided by Kubernetes to allocate dedicated cores to applications, improving application performance and reducing application scheduling latency.
CPU Policy
GPU Scheduling
CCE schedules heterogeneous GPU resources in clusters and allows GPUs to be used in containers.
Function
Documentation
Default GPU scheduling in Kubernetes
This function allows you to specify the number of GPUs that a pod requests. The value can be less than 1 so that multiple pods can share a GPU.
Default GPU Scheduling in Kubernetes
NPU Scheduling
CCE schedules heterogeneous NPU resources in a cluster to quickly and efficiently perform inference and image recognition.
Function
Documentation
NPU scheduling
NPU scheduling allows you to specify the number of NPUs that a pod requests to provide NPU resources for workloads.
NPU Scheduling
Volcano Scheduling
Volcano is a Kubernetes-based batch processing platform that supports machine learning, deep learning, bioinformatics, genomics, and other big data applications. It provides general-purpose, high-performance computing capabilities, such as job scheduling, heterogeneous chip management, and job running management.
Function
Documentation
Scheduling workloads
Kubernetes typically uses its default scheduler to schedule workloads. To use Volcano, specify Volcano for your workloads.
Scheduling Workloads
NUMA affinity scheduling
Volcano targets to lift the limitation to make scheduler NUMA topology aware so that:
  • Pods are not scheduled to the nodes that NUMA topology does not match.
  • Pods are scheduled to the best node for NUMA topology.
NUMA Affinity Scheduling
