Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
Network>
Cluster Network Settings>
Switching a Node Subnet
Updated on 2024-01-04 GMT+08:00
This section describes how to switch subnets for nodes in a cluster.
- Only subnets in the same VPC as the cluster can be switched. The security group of the node cannot be switched.
- Log in to the ECS console.
- Click More > Manage Network > Change VPC in the Operation column of the target ECS.
- Set parameters for changing the VPC.
- VPC: Select the same VPC as that of the cluster.
- Subnet: Select the target subnet to be switched.
- Private IP Address: Select Assign new or Use existing as required.
- Security Group: Select the security group of the cluster node. Otherwise, the node is unavailable.
- Click OK.
- Go to the CCE console and reset the node. You can use the default parameter settings. For details, see Resetting a Node.
Parent topic: Cluster Network Settings
