Updated on 2024-01-04 GMT+08:00
Release Notes for CCE Cluster Versions
Version 1.27
In CCE v1.27 and later versions, all nodes support only the containerd container engine.
Table 1 Release notes for the v1.27 patch
CCE Cluster Patch Version
Kubernetes Version
Feature Updates
Optimization
Vulnerability Fixing
v1.27.1-r0
v1.27.2
CCE clusters of v1.27 are released for the first time. For more information, see Kubernetes 1.27 Release Notes.
  • Both soft eviction and hard eviction are supported in node pool configurations.
None
None
Version 1.25
All nodes in the CCE clusters of version 1.25, except the ones running EulerOS 2.5, use containerd by default.
Table 2 Release notes for the v1.25 patch
Kubernetes Version
Feature Updates
Optimization
v1.25.3-r10
v1.25.5
The timeout interval can be configured for a load balancer.
High-frequency parameters of kube-apiserver are configurable.
Fixed some security issues.
v1.25.3-r0
v1.25.5
None
Enhanced network stability of CCE Turbo clusters when their specifications are modified.
v1.25.1-r0
v1.25.5
CCE clusters of v1.25 are released for the first time. For more information, see Kubernetes 1.25 Release Notes.
None
None
Version 1.23
Table 3 Release notes for the v1.23 patch
Kubernetes Version
Feature Updates
Optimization
v1.23.8-r10
v1.23.11
v1.23.8-r0
v1.23.11
None
  • Enhanced Docker reliability during upgrades.
  • Optimized node time synchronization.
v1.23.5-r0
v1.23.11
  • Fault detection and isolation are supported on GPU nodes.
  • Security groups can be customized by cluster.
  • CCE Turbo clusters support ENIs pre-binding by node.
  • containerd is supported.
  • The ETCD version of the master node has been upgraded to the Kubernetes version 3.5.6.
  • Scheduling is optimized so that pods are evenly distributed across AZs after pods are scaled in.
  • Optimized the memory usage of kube-apiserver when CRDs are frequently updated.
Fixed some security issues and the following CVE vulnerabilities:
v1.23.1-r0
v1.23.4
CCE clusters of v1.23 are released for the first time. For more information, see Kubernetes 1.23 Release Notes.
None
None
Version 1.21
Table 4 Release notes for the v1.21 patch
Kubernetes Version
Feature Updates
Optimization
v1.21.10-r10
v1.21.14
v1.21.10-r0
v1.21.14
None
  • Enhanced the stability of the Docker runtime for pulling images after nodes are restarted.
v1.21.7-r0
v1.21.14
Improved the stability of LoadBalancer Services/ingresses with a large number of connections.
v1.21.1-r0
v1.21.7
CCE clusters of v1.21 are released for the first time. For more information, see Kubernetes 1.21 Release Notes.
None
None
Version 1.19
Table 5 Release notes for the v1.19 patch
Kubernetes Version
Feature Updates
Optimization
v1.19.16-r30
v1.19.16
v1.19.16-r20
v1.19.16
None
  • Cloud Native 2.0 Networks allow you to specify subnets for a namespace.
  • Optimized the performance of CCE Turbo clusters in allocating ENIs if not all ENIs are pre-bound.
v1.19.16-r4
v1.19.16
  • Scheduling is optimized on taint nodes.
  • Enhanced the long-term running stability of containerd when cores are bound.
  • Improved the stability of LoadBalancer Services/ingresses with a large number of connections.
v1.19.16-r0
v1.19.16
None
Enhanced the stability in updating LoadBalancer Services when workloads are upgraded and nodes are scaled in or out.
v1.19.10-r0
v1.19.10
CCE clusters of v1.19 are released for the first time. For more information, see Kubernetes 1.19 Release Notes.
None
None
