Updated on 2026-09-23 GMT+08:00
Configuring WORM for Objects
If you want to prevent any user (including the bucket or object owner) from modifying or deleting specific objects in an OBS bucket for a specified period, you can configure object-level WORM.
This section describes how to configure WORM for objects when uploading them or after they are uploaded.
  • A bucket-level WORM policy applies only to objects uploaded after the policy is configured. To protect existing objects, configure object-level WORM separately.
  • The metadata of a WORM-protected object can still be modified.
Important Notes
  • Before configuring object-level WORM, you must enable bucket-level WORM. If an object is protected by both bucket-level and object-level WORM, the object-level WORM policy takes precedence.
  • The retention period of object-level WORM can only be extended but cannot be shortened.
  • If you have deregistered your account or your account has been frozen, the WORM-protected objects will be permanently deleted.
  • WORM does not protect parts generated during multipart uploads.
  • If a bucket has WORM enabled, an append upload on this bucket will fail, with a 403 error returned.
  • Only the compliance mode is supported.
Access Control
To configure an object-level WORM policy, you must be the object owner or have the required permission. For authorization details, see Object-Level WORM Authorization Settings.
WORM has been enabled for the bucket.
Configuring WORM When Uploading Objects
You can use OBS Console or APIs to configure object-level WORM. You cannot use SDKs, OBS Browser+, or obsutil to do so.
Configuring WORM or Extending the Retention Period After Objects Are Uploaded
If an object does not have WORM configured or its retention period needs to be extended, perform the following steps:
