Updated on 2023-10-26 GMT+08:00
Error Code List
If a request fails to be processed due to errors, an error response is returned. An error response contains an error code and error details. Table 1 lists some common error codes in OBS error responses.
Table 1 OBS error codes
Error Code
Obs.0000
Invalid parameter.
Obs.0001
All access requests to this object are invalid.
Obs.0002
The absolute path of a file cannot exceed 1023 characters. Please retry.
Obs.0003
The connection timed out.
Obs.0004
Time difference is longer than 15 minutes between the client and server. Correctly set the local time.
For security purposes, OBS verifies the time offset between the client and server. If the offset is longer than 15 minutes, the OBS server will reject your requests and this error message is reported. To resolve this problem, adjust your local time (UTC) and try again.
Obs.0005
The server load is too heavy. Try again later.
Obs.0006
The number of buckets has reached the upper limit.
An account (including all IAM users under this account) can create a maximum of 100 buckets and parallel file systems. You can use the fine-grained access control of OBS to properly plan and use buckets.
Obs.0007
The target bucket does not exist or is not in the same region with the current bucket.
Obs.0008
The account has not been registered with the system. Only a registered account can be used.
Obs.0009
A conflicting operation is being performed on this resource. Please retry.
This is because that there is a bucket with the same name as the bucket you are creating in OBS and the existing bucket has been released in the recent period due to arrears. In such case, try another bucket name.
Obs.0010
Deletion failed. Check whether objects or objects of historical versions exist in the bucket.
Obs.0011
The bucket policy is invalid. Configure it again.
Obs.0012
The requested bucket name already exists. Bucket namespace is shared by all users in the system. Enter a different name and try again.
Obs.0013
The requested folder name already exists. Enter a different name and try again.
Obs.0014
The file size has exceeded 50 MB. Use OBS Browser+ to upload it.
Obs.0015
The absolute path in the search criteria cannot exceed 1023 characters. Please retry.
Obs.0016
Upload failed. Possible causes:
  1. The network is abnormal.
  2. You have incorrect or no permissions to write the bucket.
  3. Your account is in arrears or has insufficient balance.
  4. Your account has been frozen.
Obs.0017
The end time of the new validity period must be later than that of the old validity period.
Obs.0018
The validity period cannot be shorter than the remaining period.
Obs.0019
Cannot determine whether the bucket has objects or fragments. Check whether you have the read permission for this bucket.
Obs.0020
TMS system error. Try again later.
Obs.0021
You do not have permissions to access TMS. Configure the required permissions in IAM.
Obs.0022
The TMS system is busy. Try again later.
