Help Center>
Object Storage Service>
Console Operation Guide>
Getting Started>
Downloading an Object
Updated on 2024-04-01 GMT+08:00
You can download files from OBS Console to your local computer.
- Objects in the Archive or Deep Archive storage class can be downloaded only when they are in the Restored state.
- Batch download is not supported on OBS Console. To batch download files or folders, you can use OBS Browser+ or obsutil.
- In the navigation pane of OBS Console, choose Object Storage.
- In the bucket list, click the bucket you want to operate to go to the Objects page.
- Select the file you want to download, and click Download or choose More > Download As on the right.
In the Download As dialog box, right-click the object and choose Copy Link Address from the shortcut menu to obtain the object's download address.
Parent topic: Getting Started
