Updated on 2022-12-02 GMT+08:00
CTS Alarms
NetworkPermissions
A malicious IP address similar to historical intelligence is found calling an API that is typically used to change permission of network access to security groups, routes, and ACLs in your account.
Severity: This alarm can be of any severity levels within High, Medium, and Low. MTD determines the potential risk the finding could have to your network.
Data source: CTS logs
A malicious IP address similar to historical intelligence is detected. The IP address tried to call an API that is typically used to change permission of network access to security groups, routes, and ACLs in your account.
Suggestions
If this is an expected activity, add the IP address to the whitelist.
ResourcePermissions
A malicious IP address similar to historical intelligence is found calling an API that is typically used to change secure access policies for various resources in your account.
A malicious IP address similar to historical intelligence is detected. The IP address tried to call an API that is typically used to change secure access policies for various resources in your account.
Suggestions
UserPermissions
A malicious IP address similar to historical intelligence is found calling an API that is typically used to add, modify, or delete IAM users, groups, or policies in your account.
A malicious IP address similar to historical intelligence is detected. The IP address tried to call an API that is typically used to add, modify, or delete IAM users, groups, or policies in your account.
Suggestions
ComputeResources
A malicious IP address similar to historical intelligence is found calling an API that is typically used to start compute resources, such as ECS instances.
A malicious IP address similar to historical intelligence is detected. The IP address tried to call an API that is usually used to start computing resources, such as ECS instances.
Suggestions
PasswordPolicyChange
A malicious IP address similar historical intelligence is found trying to change the account password policy.
A malicious IP address similar to historical intelligence is detected. The IP address tried to change the account password policy.
Suggestions
