Configuring Spark2x Data Encryption During Transmission
This section describes how to configure encryption for Spark2x security channels to enhance security.
To modify parameters, log in to FusionInsight Manager, click Cluster and choose Services > Spark2x. On the displayed page, click Configurations and click All Configurations. Enter a parameter name in the search box.
After the configuration, restart the corresponding service for the settings to take effect.
Parameter |
Description |
Default Value |
spark.authenticate |
Whether to enable Spark internal security authentication |
Security mode: true Normal mode: false |
spark.authenticate.enableSaslEncryption |
Whether to enable encrypted communication based on Simple Authentication and Security Layer (SASL) |
spark.network.crypto.enabled |
Whether to enable RPC encryption based on Advanced Encryption Standard (AES) |
spark.network.sasl.serverAlwaysEncrypt |
Whether to disable unencrypted connections for ports with SASL authentication enabled |
false |
spark.network.crypto.keyLength |
Length of the encryption key to be generated |
256 |
spark.network.crypto.keyFactoryAlgorithm |
Algorithm used to generate the encryption key |
PBKDF2WithHmacSHA1 |
spark.io.encryption.enabled |
Whether to enable local disk I/O encryption |
spark.io.encryption.keygen.algorithm |
Algorithm used to generate the I/O encryption key |
HmacSHA256 |
spark.io.encryption.keySizeBits |
Size of an I/O encryption key, in bits |
256 |
spark.ssl.ui.enabled |
Whether to enable Secure Sockets Layer (SSL) authentication for the web UI connection |
