Viewing Backup and Restoration Tasks
This section describes how to view created backup and recovery tasks and check their running status on FusionInsight Manager.
You have logged in to FusionInsight Manager.
- On FusionInsight Manager, choose O&M > Backup and Restoration.
- Click Backup Management or Restoration Management.
- In the task list, obtain the previous execution result in the Task Status and Task Progress column. Green indicates that the task is executed successfully, and red indicates that the execution fails.
- In the Operation column of a specified task in the task list, choose or click View History to view the historical record of backup and restoration task execution.
In the displayed window, click
before a specified record to display log information about the execution.
Related Tasks
- Starting a backup or restoration task
In the task list, locate a specified task and choose More > Back Up Now or click Start in the Operation column to start a backup or restoration task that is ready or fails to be executed. Executed restoration tasks cannot be repeatedly executed.
- Stopping a backup or restoration task
In the task list, locate a specified task and choose More > Stop or click Stop in the Operation column to stop a backup or restoration task that is running. After the task is successfully stopped, its Task Status changes to Stopped.
- Deleting a backup or restoration task
In the Operation column of a specified task, choose More > Delete or click Delete and then click OK in the displayed dialog box to delete the backup and restoration task. Backup data will be reserved by default after a task is deleted.
- Suspending a backup task
In the task list, locate a specified task and choose More > Suspend in the Operation column to suspend a backup task. Only periodic backup tasks can be suspended. Suspended backup tasks are no longer executed automatically. When you suspend a backup task that is being executed, the task execution stops. To resume a task, choose More > Resume.
