Updated on 2022-09-23 GMT+08:00
Modifying a Backup Task
This section describes how to modify the parameters of a created backup task on FusionInsight Manager to meet changing service requirements. The parameters of restoration tasks can only be viewed but cannot be modified.
Impact on the System
After a backup task is modified, the new parameters take effect when the task is executed next time.
  • A backup task has been created.
  • A new backup task policy has been planned based on the actual situation.
  1. On FusionInsight Manager, choose O&M > Backup and Restoration > Backup Management.
  2. In the task list, locate a specified task, click Configure in the Operation column to go to the configuration modification page.
    On the displayed page, modify the following parameters:
    • Started
    • Period
    • Destination NameService Name
    • Target NameNode IP Address
    • Target Path
    • Max Number of Backup Copies
    • Maximum Number of Recovery Points
    • Maximum Number of Maps
    • Maximum Bandwidth of a Map
    After the Target Path parameter of a backup task is modified, this task will be performed as a full backup task for the first time by default.
  3. Click OK to save the settings.
