Updated on 2026-09-08 GMT+08:00
Overview of Data Migration Scenarios
To centrally analyze and manage scattered data from various systems, you can utilize migration tools like Cloud Data Migration (CDM) to migrate the data to DLI. Once the migration is complete, you can submit DLI jobs to analyze the data.
CDM supports multiple types of data sources, such as databases, data warehouses, and files. You can configure data source migration tasks on the GUI to enhance the efficiency of data migration and integration.
Figure 1 Migrating data to DLI
Data Type Mapping
Refer to Table 2 for data type mapping between data sources and destinations during data migration between DLI and other cloud services and platforms. This will aid in data type conversion and mapping.
Table 2 Data type mapping
MySQL
Hive
DWS
Oracle
PostgreSQL
Hologres
DLI Spark
CHAR
CHAR
CHAR
CHAR
CHAR
CHAR
CHAR
VARCHAR
VARCHAR
VARCHAR
VARCHAR
VARCHAR
VARCHAR
VARCHAR/STRING
DECIMAL
DECIMAL
NUMERIC
NUMERIC
NUMERIC
DECIMAL
DECIMAL
INT
INT
INTEGER
NUMBER
INTEGER
INTEGER
INT
BIGINT
BIGINT
BIGINT
NUMBER
BIGINT
BIGINT
BIGINT/LONG
TINYINT
TINYINT
SMALLINT
NUMBER
SMALLINT
SMALLINT
TINYINT
SMALLINT
SMALLINT
SMALLINT
NUMBER
SMALLINT
SMALLINT
SMALLINT/SHORT
BINARY
BINARY
BYTEA
RAW
BYTEA
BYTEA
BINARY
VARBINARY
BINARY
BYTEA
RAW
BYTEA
BYTEA
BINARY
FLOAT
FLOAT
FLOAT4
FLOAT
DOUBLE
FLOAT4
FLOAT
DOUBLE
DOUBLE
FLOAT8
FLOAT
REAL/DOUBLE
FLOAT8
DOUBLE
DATE
DATE
TIMESTAMP
DATE
DATE
DATE
DATE
TIME
Not supported (use String instead)
TIME
DATE
TIME
TIME
DATETIME
TIMESTAMP
TIMESTAMP
TIME
TIME
TIMESTAMP
TIMESTAMP
TINYINT
TINYINT
BOOLEAN
Not supported
TINYINT
BOOLEAN
BOOLEAN
Not supported (use TEXT instead)
Not supported (use VARCHAR instead)
ARRAY
MAP
STRUCT
If a service does not support a standard data type, you can use the recommended data type.
