Changing the Table Owner on the DLI Console
In practical use, developers create databases and tables, which are then handed over to testers for testing. Once testing is complete, the databases and tables are handed over to O&M personnel for experience. In this scenario, ownership of the data can be transferred to another owner by changing the table owner.
- Log in to the DLI management console.
- In the navigation pane, choose Data Management > Databases and Tables.
- Click the name of the database whose tables you want to modify.
- Locate the table for which you want to change the owner, click More in the Operation column, and select Modify Owner.
- In the displayed Modify Owner dialog box, enter a new owner name (an existing username) and click OK.
