Allocating a Queue to an Enterprise Project
You can create enterprise projects matching the organizational structure of your enterprises to centrally manage cloud resources across regions by project. Then you can create user groups and users with different permissions and add them to enterprise projects.
DLI allows you to select an enterprise project when creating a queue. This section describes how to bind a DLI queue to and modify an enterprise project.
Currently, enterprise projects can be modified only for queues that have not been added to elastic resource pools.
You have logged in to the Enterprise Project Management Service console and created an enterprise project by referring to Creating an Enterprise Project.
Modifying an Enterprise Project
You can change the enterprise project associated with a queue that has been created.
- Log in to the DLI management console.
- In the navigation pane on the left, choose Resources > Queue Management.
- In the queue list, locate the queue for which you want to modify the enterprise project, click More in the Operation column, and select Modify Enterprise Project.
- In the Modify Enterprise Project dialog box displayed, select an enterprise project.
Alternatively, you can click Create Enterprise Project to go to the Enterprise Project Management Service console to create an enterprise project and check existing ones.
- After the modification, click OK to save the enterprise project information of the queue.
Related Operations
For details about how to modify the enterprise project of an elastic resource pool, see Allocating to an Enterprise Project.
