Help Center/ Data Lake Insight/ User Guide/ Common DLI Management Operations/ Managing Program Packages of Jar Jobs/ Changing the DLI Package Owner
Updated on 2026-09-08 GMT+08:00
DLI allows you to change the owner of a package group or package.
- Log in to the DLI management console and choose Data Management > Package Management.
- On the Package Management page, locate the package whose owner you want to change, click More in the Operation column, and select Modify Owner.
- If the package has been grouped, you can change the owner of the group or package by selecting Group or Packages for Select Type and entering the new owner's username in Username. Figure 1 Modifying the package owner
- If the package has not been grouped, change its owner directly. Figure 2 Modifying the owner of a package
Table 1 Description Parameter
Group Name
- If you select a group when creating a package, the name of the group is displayed.
- If no group is selected when creating a package, this parameter is not displayed.
Name
Name of a package.
Select Type
- If you select a group when creating a package, you can change the owner of the group or package.
Username
Name of the package owner.
NOTE:The username is the name of an existing IAM user.
- Click OK.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
