Configuring Table Permissions on the DLI Console
Operation Scenario
- By setting permissions, you can assign varying table permissions to different users.
- The administrator and table owner have all permissions, which cannot be set or modified by other users.
- When setting table permissions for a new user, ensure that the region of the user group the user belongs to has the Tenant Guest permission. For details about the Tenant Guest permission and how to apply for the permission, see Permissions Policies and Creating a User Group and Assigning Permissions in the Identity and Access Management User Guide.
Precautions
- If you want to view tables in the database of the master account, you need to grant the display permission to the current IAM user. For details, see Common Operations Supported by Each System Permission.
- If you create a table with the same name as a deleted table, the table permissions will not be inherited. In this case, you need to grant the table permissions to users or projects.
For example, user A is granted with the permission to delete the testTable table. Delete the table and create another one with the same name. You need to grant user A the deletion permission of the testTable table again.
Viewing Table Permissions
- Log in to the DLI management console.
- In the navigation pane, choose Data Management > Databases and Tables.
- Click the database name in the table whose authority is to be set. The Table Management page of the database is displayed.
- Locate the row where the target table resides and click Manage Permissions in the Operation column. Figure 1 Table permission management
Permissions can be granted to new users or projects, modified for users or projects with existing permissions, or revoked from a user or project.
Granting Permissions to a New User or Project
- Locate a database and click Permissions in the Operation column.
- In the upper right corner of the displayed page, click Grant Permission.
- In the displayed Grant Permission dialog box, select the required permissions.
- For details about the DLI table permissions, see Table 1. Figure 2 Granting DLI table permissions to a user
Figure 3 Granting DLI table permissions to a project
Table 1 Parameter descriptions Parameter
Authorization Object
Select User or Project.
Username/Project
- If you select User, enter the IAM username when granting table permissions to the user. NOTE:
The username must be an existing IAM username and has been used to log in to the DLI management console.
- If you select Project, select the project to be authorized in the current region. NOTE:
If you select Project, you can only view information about the authorized tables and their databases.
Non-inheritable Permissions
Select a permission to grant it to the user, or deselect a permission to revoke it.
- The following permissions are applicable to both user and project authorization:
- Select Table: This permission allows you to query data of the current table.
- View Table Information: This permission allows you to view information about the current table.
- View Table Creation Statement: This permission allows you to view the statement for creating the current table.
- Drop Table: This permission allows you to delete the current table.
- Rename Table: Rename the current table.
- Insert: This permission allows you to insert data into the current table.
- Overwrite: This permission allows you to insert data to overwrite the data in the current table.
- Add Column: Add columns to the current table.
- Grant Permission: The current user can grant table permissions to other users.
- Revoke Permission: The current user can revoke the table's permissions that other users have but cannot revoke the table owner's permissions.
- View Other Users' Permissions: This permission allows you to query other users' permission on the current table.
The partition table also has the following permissions:
- Delete Partition: This permission allows you to delete existing partitions from a partition table.
- View All Partitions: This permission allows you to view all partitions in a partition table.
- The following permissions can only be granted to users:
- View Table: This permission allows you to display the current table.
- For details about the OBS table permissions, see Table 2. Figure 4 Granting OBS table permissions to a user
Figure 5 Granting OBS table permissions to a project
Table 2 Parameter descriptions Parameter
Username/Project
Select a permission to grant it to the user, or deselect a permission to revoke it.- The following permissions are applicable to both user and project authorization:
- Add Column: This permission allows you to add columns to the current table.
- Grant Permission: This permission allows you to grant table permissions to other users or projects.
- Revoke Permission: This permission allows you to revoke the table's permissions that other users or projects have but cannot revoke the table owner's permissions.
The partition table also has the following permissions:- Add Partition: This permission allows you to add a partition to a partition table.
- Configure Path for Partition: This permission allows you to set the path of a partition in a partition table to a specified OBS path.
- Rename Table Partition: This permission allows you to rename partitions in a partition table.
- Restore Table Partition: This permission allows you to export partition information from the file system and save the information to metadata.
- View Table: This permission allows you to view the current table.
- For details about the view permissions, see Table 3.
Views can be created only by using SQL statements, not through the Create Table page.
Figure 6 Granting view permissions to a user
Figure 7 Granting view permissions to a project
Table 3 Parameter descriptions Parameter
Username/Project
- If you select User, enter the IAM username when adding a user to the database. NOTE:
- Grant Permission: The current user or project can grant table permissions to other users or projects.
- Revoke Permission: The current user or project can revoke the table's permissions that other users or projects have but cannot revoke the table owner's permissions.
- Only applicable to
- Click OK.
Modifying Permissions for an Existing User or Project
For a user or project that has some permissions on the database, you can revoke the existing permissions or grant new ones.
If all options under Set Permission are gray, you are not allowed to change permissions on this table. You can apply to the administrator, table owner, or other authorized users for granting and revoking table permissions.
- On the DLI console, and choose Data Management > Databases and Tables in the navigation pane on the left. On the displayed page, locate the target database and click Permissions in the Operation column. In the user permissions list, locate the target user:
- If the user is an IAM user and is not the owner of the table, you can set permissions.
- If the user is an administrator or table owner, you can only view permissions.
In the Project Permission Info list, locate the project for which you want to set permissions and click Set Permission.
- In the Operation column of the IAM user or project, click Set Permission. The Set Permission dialog box is displayed.
- Click OK.
Revoking All Permissions of a User or Project
Revoke all permissions of a user or a project.
- On the DLI console, and choose Data Management > Databases and Tables in the navigation pane on the left. Locate the target database and click Permissions in the Operation column. In the User Permissions area, locate the target user and click Revoke Permission in the Operation column. In the displayed dialog box, click OK.
In the following cases, Revoke Permission is gray, indicating that the permission of the user cannot be revoked.
- The user is an administrator.
- The IAM user is the owner of the table.
- The IAM user has only inheritable permissions.
- In the Project Permission Info area, select the project whose permissions need to be revoked and click Revoke Permission in the Operation column. After you click OK, the project does not have any permissions on the table.
If a project has only inheritable permissions, Revoke Permission is gray, indicating that the permissions of the project cannot be revoked.
