Updated on 2026-09-08 GMT+08:00
DLI Agency Overview
What Is an Agency?
Cloud services often need to interact with each other for business operations. In some cases, one cloud service may require collaboration with another. To facilitate this, you can create a cloud service agency, which grants operational permissions to DLI. This allows DLI to act on your behalf when using other cloud services, enabling it to perform resource management tasks for you.
For example, when creating a Flink job in DLI, the required AK/SK is stored in DEW. If you want DLI to access DEW data during job execution, you must provide an IAM agency. This grants the necessary permissions to DLI, allowing it to access DEW on your behalf.
Figure 1 DLI service agency
DLI Agencies
Before using DLI, you are advised to set up DLI agency permissions to ensure the proper functioning of DLI.
  • By default, DLI provides the following agencies: dli_admin_agency, dli_management_agency, and dli_data_clean_agency. The names of these agencies are fixed, but the permissions contained in them can be customized. In other scenarios, you need to create custom agencies. For details about the agencies, see Table 1.
  • DLI upgrades dli_admin_agency to dli_management_agency to meet the demand for fine-grained agency permissions management. The new agency has the necessary permissions for datasource operations, notifications, and user authorization operations. For details, see Configuring DLI Agency Permissions.
  • To maintain compatibility with existing job agency permission requirements, dli_admin_agency will still be listed in the IAM agency list even after the update.
  • Only the tenant account or a member account of user group admin can authorize the service.
  • Do not delete the agency created by the system by default.
Table 1 DLI agencies
Agency
Type
dli_admin_agency
Default agency
This agency has been deprecated and is not recommended. Upgrade the agency to dli_management_agency as soon as possible.
For details about how to update an agency, see Configuring DLI Agency Permissions.
Default agency
DLI system agency, which is used to delegate operation permissions to DLI so that DLI can use other cloud services and perform resource O&M operations on your behalf. This agency grants permissions for datasource operations, message notifications, and user authorization operations. For details about the permissions of an agency, see Table 2.
Default agency, which needs to be authorized by users
Data cleanup agency, which is used to clean up data according to the lifecycle of a table and clean up lakehouse table data. You need to create a DLI agency named dli_data_clean_agency on IAM and grant permissions to it.
You need to create an agency and customize permissions for it. However, the agency name is fixed to dli_data_clean_agency.
For details about the permission policies of an agency, see Agency Permission Policies in Common Scenarios.
Other custom agencies
Custom agency
When using Flink 1.15, Spark 3.3, or a later version to execute jobs, create an agency on the IAM console and add new agency information to the job configuration. For details, see Creating a Custom DLI Agency.
Common scenarios for creating an agency: DLI is allowed to read and write data from and to OBS to transfer logs. DLI is allowed to access DEW to obtain data access credentials and access catalogs to obtain metadata.
You cannot use the default agency names dli_admin_agency, dli_management_agency, or dli_data_clean_agency. It must be unique.
Table 2 Permissions contained in the dli_management_agency agency
Policy
IAM ReadOnlyAccess
To authorize IAM users who have not logged in to DLI, you need to obtain their information. So, the permissions contained in the IAM ReadOnlyAccess policy are required.
DLI Datasource Connections Agency Access
Permissions to access and use VPCs, subnets, routes, and VPC peering connections
DLI Notification Agency Access
Permissions to send notifications through SMN when a job fails to be executed
Notes and Constraints
  • To use Flink 1.15, Spark 3.3.1 (Spark general queue scenario), or a later version to execute jobs, perform the following operations:
    Create an agency on the IAM console and add the agency information to the job configuration. For details, see Creating a Custom DLI Agency.
    • Common scenarios for creating an agency: DLI is allowed to read and write data from and to OBS, dump logs, and read and write Flink checkpoints. DLI is allowed to access DEW to obtain data access credentials and access catalogs to obtain metadata.
    • You cannot use the default agency names dli_admin_agency, dli_management_agency, or dli_data_clean_agency. It must be unique.
  • If the engine version is earlier than Flink 1.15, dli_admin_agency is used by default during job execution. If the engine version is earlier than Spark 3.3.1, user authentication information (AK/SK and security token) is used during job execution.
    This means that jobs whose engine versions are earlier than Flink 1.15 or Spark 3.3.1 are not affected by the update of agency permissions and do not require custom agencies.
