Updated on 2026-09-08 GMT+08:00
Package Management Overview
Before running DLI jobs, UDF JAR files or Jar job packages need to be uploaded to the cloud platform for unified management and maintenance.
There are two ways to manage packages:
  • (Recommended) Upload packages to OBS: Upload Jar packages to an OBS bucket in advance and select the OBS path when configuring a job.
  • The DLI package function will soon be discontinued. Upload packages to DLI: Upload Jar packages to an OBS bucket in advance, create a package on the Data Management > Package Management page of the DLI management console, and select the DLI package when configuring a job.
This section describes how to upload and manage packages on the DLI management console.
  • The DLI package function will soon be discontinued. When using Spark 3.3.1 or later or Flink 1.15 or later to run jobs, you are advised to select packages stored in OBS.
  • When packaging Spark or Flink Jar jobs, do not upload the dependency packages that the platform already has to avoid conflicts with the built-in dependency packages of the platform. Refer to DLI Built-in Dependencies for built-in dependency packages.
Notes and Constraints
Table 1 Notes and constraints on package usage
Item
Package
  • A package can be deleted, but a package group cannot be deleted.
  • The following types of packages can be uploaded:
    • JAR: JAR file
    • PyFile: User Python file
    • File: User file
    • ModelFile: User AI model file
Package Management Page
Table 2 Package management parameters
Group Name
Name of the group to which the package belongs. If the package is not grouped, -- is displayed.
Package Name
Name of a package.
Owner
Name of the user who uploads the package.
Type
Type of a package. The following package types are supported:
  • JAR: JAR file
  • File: User file
Status
Status of the package to be created.
  • Uploading: The file is being uploaded.
  • Finished: The resource package has been uploaded.
  • Failed: The resource package upload failed.
Created
Time when a package is created.
Updated
Time when the package is updated.
Operation
Manage Permissions: Manage user permissions for a package.
Delete: Delete the package.
More:
  • Modify Owner: Modify the owner of the package.
  • Tags: Add or edit package tags.
