Help Center/ Data Lake Insight/ User Guide/ Creating a Database, Data Catalog, and Table/ Creating a Database, Data Catalog, and Table on the DLI Console
Updated on 2026-09-08 GMT+08:00
  • A data catalog is a metadata management object that can contain multiple databases.
    Data catalogs are used to create LakeFormation data catalog mappings on the DLI console in the scenario of DLI integration with LakeFormation. The DLI integration with LakeFormation function is currently in the limited use phase. You need to submit a service ticket to enable this function. After this function is enabled, you can view data catalogs on the SQL Editor page of the DLI management console.
    DLI currently supports DLI data catalogs and LakeFormation data catalogs:
    • DLI data catalog: The data catalog service provided by DLI, which is used to store and manage metadata in a data lake. The default name of a DLI data catalog is dli.
    • LakeFormation data catalog: LakeFormation provides unified metadata management. You need to create a connection to a LakeFormation catalog on the DLI management console to access the catalog stored within a LakeFormation instance. After connecting DLI to the default LakeFormation instance and authorizing access to LakeFormation resources, you can use LakeFormation metadata during DLI job development.
  • A database is a repository of data organized, stored, and managed on computer storage devices according to data structures.
  • A table is one of the most essential components of a database. It is composed of rows and columns, with each column regarded as a field. The values within each field represent a specific type of data.
    A database is a framework, and tables are its essential content. A database contains one or more tables.
You can create databases and tables on the management console or using SQL statements.
For details about how to create a database and table using SQL statements, see Creating a Database, Creating an OBS Table, and Creating a DLI Table.
This section describes how to create a data catalog, database, and table on the management console.
  • Views can be created only by using SQL statements, not through the Create Table page.
  • For Hudi tables created using SQL statements, you need to configure Hive synchronization parameters before they can be checked in the databases and tables on the DLI management console.
    Why Is a Hudi Table Not Displayed on the DLI Console?
Precautions
When creating a data catalog, database, or table, you have required permissions by default. You need to grant permissions to other users so that they can view the created data catalog, database, or table.
Creating a Data Catalog
The DLI management console provides the DLI data catalog by default. You can also follow this section's instructions to create a connection to a LakeFormation catalog on the DLI management console. Once created, the LakeFormation catalog will be displayed under the data catalog list on the DLI management console.
  1. Before creating a connection to a LakeFormation catalog on DLI, ensure that a data catalog has been created on the LakeFormation management console.
    1. Log in to the LakeFormation management console.
    2. In the navigation pane, choose Metadata > Catalog.
    3. On the displayed page, click Create.
      Set catalog instance parameters as needed.
      For parameter settings and descriptions, see Creating a Catalog.
    4. Once created, you can view information about the created catalog on the Catalog page.
      DLI can only connect to the default LakeFormation instance. Set the instance in LakeFormation as the default to ensure successful connection.
  2. Create a data catalog on the DLI management console.
    On the DLI management console, you need to create a connection to a LakeFormation catalog to enable access to the catalog stored within a LakeFormation instance when submitting jobs on DLI.
    You can create data catalog connections on three pages of the DLI management console, and the created data catalog connections will be visible under the Catalog tab of the SQL Editor page.
    • On the Catalog tab of the SQL Editor page, click to create a connection to a LakeFormation catalog.
    • On the Flink job editing page, click next to Catalog Name to create a connection to a LakeFormation catalog. (Only Flink 1.17 or later supports configuring data catalogs.)
    • On the Spark job editing page, click next to Catalog Name to create a connection to a LakeFormation catalog. (Only Spark 3.3.1 supports configuring data catalogs.)
    You can only create one mapping for each data catalog in LakeFormation.
    For example, a user creates a mapping named catalogMapping1 in DLI, which corresponds to the data catalog catalogA in LakeFormation. Once created, you cannot create a mapping to catalogA in the same project space.
    Take creating a data catalog connection on the Catalog tab of the SQL Editor page as an example:
    1. Log in to the DLI management console.
    2. In the navigation pane, choose SQL Editor.
    3. On the SQL editor page, select a data catalog under Catalog.
    4. Click to create a data catalog.
    5. In the Create Catalog dialog box, set data catalog parameters.
      Table 1 Data catalog parameters
      Mandatory
      External Catalog Name
      Yes
      Catalog name of the default LakeFormation instance.
      Type
      Yes
      Currently, the only available option is LakeFormation.
      This option is fixed and does not need to be selected.
      Catalog Name
      Yes
      Catalog mapping name used in DLI. When running SQL statements, you need to specify the catalog mapping to identify the external metadata to be accessed. You are advised to set this parameter to the same value as External Catalog Name.
      Currently, DLI can only connect to the data catalog of the default LakeFormation instance.
      No
      Description of the data catalog.
    6. Click OK.
    7. After the data catalog is created, the connection status of the data catalog is displayed in the data catalog list.
      • Blinking indicates that the data catalog is being created.
      • indicates that the data catalog has been created and the data catalog connection has been activated.
      • indicates that the data catalog fails to be created. In this case, it is advised to delete the current data connection and create a data catalog again.
Creating a Database
  1. You can create a database on either the Data Management page or the SQL Editor page.
    • To create a database on the Data Management page:
      1. In the navigation pane of the DLI management console, choose Data Management > Databases and Tables.
      2. In the upper right corner of the Databases and Tables page, click Create Database to create a database.
    • To create a database on the SQL Editor page:
      1. In the navigation pane of the DLI management console, choose SQL Editor.
      2. In the navigation pane on the left, click next to Databases.
  2. In the displayed Create Database dialog box, specify Name and Description by referring to Table 2.
    Figure 1 Creating a database
    Table 2 Parameter descriptions
    Database Name
    • Only digits, letters, and underscores (_) are allowed. The value cannot contain only digits or start with an underscore (_).
    • The database name is case insensitive and cannot be left blank.
    • The value can contain a maximum of 128 characters.
    The default database is a built-in database. You cannot create the default. database.
    Enterprise Project
    If the created queue belongs to an enterprise project, you can select the corresponding enterprise project.
    Enterprise projects let you manage cloud resources and users by project.
    For details about how to configure enterprise projects, see Enterprise Management User Guide.
    This parameter is displayed only for users who have enabled the Enterprise Management Service.
    Description of a database.
    Tags
    Tags used to identify cloud resources. A tag includes the tag key and tag value. If you want to use the same tag to identify multiple cloud resources, that is, to select the same tag from the drop-down list box for all services, you are advised to create predefined tags on the Tag Management Service (TMS).
    If your organization has configured tag policies for DLI, add tags to resources based on the policies. If a tag does not comply with the tag policies, resource creation may fail. Contact your organization administrator to learn more about tag policies.
    For details, see Tag Management Service User Guide.
    • A maximum of 20 tags can be added.
    • Only one tag value can be added to a tag key.
    • The key name in each resource must be unique.
    • Tag key: Enter a tag key name in the text box.
      A tag key can contain a maximum of 128 characters. Only letters, digits, spaces, and special characters (_.:+-@) are allowed, but the value cannot start or end with a space or start with _sys_.
    • Tag value: Enter a tag value in the text box.
      A tag value can contain a maximum of 255 characters. Only letters, digits, spaces, and special characters (_.:+-@) are allowed.
  3. Click OK.
    After a database is created, you can view and select the database for use on the Databases and Tables page or SQL Editor page.
Creating a Table
Before creating a table, ensure that a database has been created.
  1. You can create a table on either the Databases and Tables page or the SQL Editor page.
    Datasource connection tables, such as View tables, HBase (CloudTable/MRS) tables, OpenTSDB (CloudTable/MRS) tables, DWS tables, RDS tables, and CSS tables, cannot be created. You can use SQL to create views and datasource connection tables. For details, see Data Lake Insight SQL Syntax Reference.
    • To create a table on the Data Management page:
      1. In the navigation pane on the left of the console, choose Data Management > Databases and Tables.
      2. On the Databases and Tables page, select the database for which you want to create a table. In the Operation column, click More > Create Table to create a table in the current database.
    • To create a table on the SQL Editor page:
      1. In the navigation pane on the left of the management console, choose SQL Editor.
      2. In the navigation pane of the displayed SQL Editor page, click Databases. You can create a table in either of the following ways:
        • Click a database name. In the Tables area, click on the right to create a table in the current database.
        • Click on the right of the database and choose Create Table from the shortcut menu to create a table in the current database.
  2. In the displayed Create Table dialog box, set parameters as required.
    • If you set Data Location to DLI, set related parameters by referring to Table 3.
      Figure 2 Creating a DLI table
    • If you set Data Location to OBS, set related parameters by referring to Table 3 and Table 4.
      When there are both a folder and a file with the same name in the OBS directory, creating an OBS table pointing to that path will prioritize the file over the folder.
      Figure 3 Creating an OBS table
      Table 3 Common parameters
      Example
      Table Name
      • The table name is case insensitive and cannot be left unspecified.
      • The table name can contain the dollar sign ($). An example value is $test.
      table01
      Data Location
      Data storage location. Currently, DLI and OBS are supported.
      DLI
      Description of the table.
      Column Type
      Available values: Normal or Partition
      Normal
      Column
      Name of a column in a table. The column name must contain at least one letter and can contain underscores (_). It cannot contain only digits.
      You can select Normal or Partition. Partition columns are dedicated to partition tables. User data is partitioned to improve query efficiency.
      The column name is case-insensitive and must be unique.
      name
      Type
      Data type of a column. This parameter corresponds to Column Name.
      • string: The data is of the string type.
      • int: Each integer is stored on four bytes.
      • date: The value ranges from 0000-01-01 to 9999-12-31.
      • double: Each number is stored on eight bytes.
      • boolean: Each value is stored on one byte.
      • decimal: The valid bits are positive integers ranging from 1 to 38. The decimal digits are integers less than 10.
      • smallint/short: The number is stored on two bytes.
      • bigint/long: The number is stored on eight bytes.
      • timestamp: The data indicates a date and time. The value can be accurate to six decimal points.
      • float: Each number is stored on four bytes.
      • tinyint: Each number is stored on one byte. Only OBS tables support this data type.
      string
      Column Description
      Description of a column.
      Operation
      • Add Column
      • Delete
        If the table to be created includes a great number of columns, you are advised to use SQL statements to create the table or import column information from the local EXCEL file.
      Table 4 Parameter descriptions when Data Location is set to OBS
      Example
      Data Format
      DLI supports the following data formats:
      • Parquet: DLI can read non-compressed data or data that is compressed using Snappy and gzip.
      • CSV: DLI can read non-compressed data or data that is compressed using gzip.
      • ORC: DLI can read non-compressed data or data that is compressed using Snappy.
      • JSON: DLI can read non-compressed data or data that is compressed using gzip.
      • Avro: DLI can read uncompressed Avro data.
      CSV
      Storage Path
      Enter or select an OBS path. The path can be a file or folder.
      • When creating an OBS table, you must specify a folder as the path. If a file is specified, data cannot be imported.
      • When there are both a folder and a file with the same name in the OBS directory, importing data pointing to that path will prioritize the file over the folder.
      obs://obs1/sampledata.csv
      Table Header: No/Yes
      This parameter is valid only when Data Format is set to CSV. Whether the data source to be imported contains the table header.
      Click Advanced Settings and select the checkbox next to Table Header: No. If the checkbox is selected, the table header is displayed. If the checkbox is deselected, no table header is displayed.
      User-defined Delimiter
      This parameter is valid only when Data Format is set to CSV and you select User-defined Delimiter.
      The following delimiters are supported:
      • Comma (,)
      • Vertical bar (|)
      • Tab character (\t)
      • Others: Enter a user-defined delimiter.
      Comma (,)
      User-defined Quotation Character
      This parameter is valid only when Data Format is set to CSV and you select User-defined Quotation Character.
      The following quotation characters are supported:
      • Single quotation mark (')
      • Double quotation marks (")
      • Others: Enter a user-defined quotation character.
      User-defined Escape Character
      This parameter is valid only when Data Format is set to CSV and you select User-defined Escape Character.
      The following escape characters are supported:
      • Backslash (\)
      • Others: Enter a user-defined escape character.
      Backslash (\)
      Date Format
      This parameter is valid only when Data Format is set to CSV or JSON.
      This parameter specifies the format of the date in the table and is valid only Advanced Settings is selected. The default value is yyyy-MM-dd. For definition of characters involved in the date pattern, see Table 3 in Importing Data to the Table.
      2000-01-01
      Timestamp Format
      This parameter specifies the format of the timestamp in the table and is valid only Advanced Settings is selected. The default value is yyyy-MM-dd HH:mm:ss. For definition of characters involved in the time pattern, see Table 3 in Importing Data to the Table.
      2000-01-01 09:00:00
  3. Click OK.
    After a table is created, you can view and select the table for use on the Data Management page or SQL Editor page.
Related Operations
After a table is created, you can import data from other OBS buckets to the table.
For details about how to import data, see Importing OBS Data to a DLI Table.
