Overview
The system resilience management process follows the end-to-end lifecycle—from project initiation through development to production launch—and integrates PRR by decomposing and embedding it into each phase. Grounded in architecture design, this approach coordinates contingency plans, resilience assessments, and chaos drills to establish a closed-loop system centered on lifecycle-wide reviews and continuous optimization.
Resilience center serves as an integrated management hub dedicated to building enterprise IT system resilience. Its core mandate is to systematically enhance an IT system to withstand disruptions, auto-heal, and recover rapidly from various failures—such as hardware outages, network interruptions, and unavailability of dependent services—by implementing a model that combines full-lifecycle governance with closed-loop optimization. It orchestrates key activities including architecture design, risk reviews, incident response, validation through drills, and resilience assessments to ensure the continuous and stable operation of critical services and to minimize the financial and reputational impact of incidents.
Guided by the core principles of prevention first, rapid response, and continuous improvement, the resilience center integrates cross-team (including R&D, O&M, security, and business teams) resources as well as end-to-end tools to build a comprehensive resilience management framework. This framework spans the entire system lifecycle, covering risk prediction, proactive mitigation, incident handling, and post-incident review and iteration.
Core Functions
Service lifecycle resilience control:
| Function | Description |
| Provides architecture resilience assessment criteria and design specifications to guide technical teams in incorporating resilience design concepts such as fault tolerance, disaster recovery, and decoupling during system project initiation and development phases. This ensures the development of architecture solutions that meet resilience requirements. | |
| Enables PRRs in the project initiation, development, and rollout phases. You can clearly define review criteria and blocking conditions for each phase, and verifies core elements such as the soundness of the architecture and the emergency preparedness. This ensures that the system has a solid resilience foundation before going live.
| Focus on the standardization and efficiency of emergency handling and build a comprehensive contingency plan management system.
| Simulate fault scenarios to verify system resilience and emergency response capabilities, and promote continuous optimization of resilience construction.
Benefits
- Proactive risk mitigation is achieved by implementing resilience controls and standardized reviews across the full system lifecycle, enabling early identification and elimination of risks such as architecture flaws and gaps in emergency preparedness, thereby reducing the likelihood of post-deployment incidents.
- Emergency response efficiency is improved through standardized contingency plans and centralized resource coordination, which shortens fault detection, response, and recovery duration, and thereby minimizing losses.
- Resilience capabilities are enhanced by embedding regular chaos drills and quantitative assessments into operational routines, transforming resilience practices into standardized, repeatable processes that do not rely on individual expertise.
- Compliance requirements are supported by maintaining a comprehensive audit trail of resilience activities—including PRR records, drill reports, and evaluation reports—to meet industry regulatory and internal audit obligations.
