Migrating a CCE Standard or Turbo Cluster to a CCE Autopilot Cluster
Migrating applications from CCE Standard or Turbo clusters to CCE Autopilot clusters in different AZs consists of two steps: backing up applications in the source clusters and migrating applications to the destination clusters through data restoration.
k8clone is an easy-to-use Kubernetes metadata cloning tool. It can save Kubernetes metadata (objects) as a local package and restore the metadata to the destination cluster.
For details about how to download k8clone, see Preparing for Container Migration.
How k8clone Backs Up and Restores Data
The following figure shows the data backup process.
![Click to enlarge](https://support.huaweicloud.com/intl/en-us/usermanual-cce/en-us_image_0000001552293325.png)
The following figure shows the data restoration process.
![Click to enlarge](https://support.huaweicloud.com/intl/en-us/usermanual-cce/en-us_image_0000001533981869.png)
Before the restoration, prepare a data restoration configuration file restore.json to automatically change the storage class names of PVCs and StatefulSets and the repository address of the image used by the workload during application restoration.
Example file content:
{ "StorageClass": "OldStorageClassName": "NewStorageClassName" // The StorageClassName field of PVCs and StatefulSets can be changed. "ImageRepo": "OldImageRepo1": "NewImageRepo1", //eg:"dockerhub.com": "cn-north-4.swr.huaweicloud.com" "OldImageRepo2": "NewImageRepo2", //eg:"dockerhub.com/org1": "cn-north-4.swr.huaweicloud.com/org2" "NoRepo": "NewImageRepo3" //eg:"golang": "swr.cn-north-4.myhuaweicloud.com/paas/golang" }
- StorageClass: The storage class names of PVCs and VolumeClaimTemplates are automatically changed based on settings.
- ImageRepo: The repository address of the image used by the workload can be changed. The workload can be a Deployment (including init containers), StatefulSet, orphaned pod, Job, CronJob, ReplicaSet, ReplicationController, and DaemonSet.
Application Backup Procedure
- Connect to the source cluster using kubectl. For details, see Connecting to a Cluster Using kubectl.
- Go to the directory where k8clone is located and run the backup command to back up data to a local directory and compress the data into a package.
The examples in k8clone Usage for Backup provide several common backup methods. You can select one or use other methods.
Application Restoration Procedure
- Connect to the destination cluster using kubectl. For details, see Connecting to a Cluster Using kubectl.
- Prepare the data restoration configuration file restore.json.
Create a restore.json file, modify it based on the format, and place it in the directory where k8clone is located.
Example:
{ "StorageClass": { "csi-disk": "csi-disk-new" }, "ImageRepo": { "quay.io/coreos": "swr.cn-north-4.myhuaweicloud.com/paas" } }
- Go to the directory where k8clone is located and run the restoration command to restore the backup data to the destination cluster.
Example:
./k8clone-linux-amd64 restore -d ./k8clone-dump.zip -f ./restore.json
![](https://support.huaweicloud.com/intl/en-us/usermanual-cce/public_sys-resources/note_3.0-en-us.png)
k8clone can run on Linux (x86 and Arm) and Windows. The usage is similar in both environments. This section uses the Linux (x86) environment as an example.
If Linux (Arm) or Windows is used, replace k8clone-linux-amd64 in the following command with k8clone-linux-arm64 or k8clone-windows-amd64.exe.
Run ./k8clone-linux-amd64 backup -h in the directory where k8clone is located to learn about its usage.
- -k, --kubeconfig: specifies the location of the kubeconfig file of kubectl. The default value is $HOME/.kube/config. The kubeconfig file is used to configure access to the Kubernetes cluster. The kubeconfig file contains the authentication credentials and endpoints (access addresses) required for accessing and registering the Kubernetes cluster. For details, see the Kubernetes documentation.
- -s, --api-server: Kubernetes API Server URL. The default value is "".
- -q, --context: Kubernetes Configuration Context. The default value is "".
- -n, --namespace: backs up cloud native applications of a specified namespace. Multiple namespaces are separated by commas (,), for example, ns1,ns2,ns3. The default value is "", indicating that the entire cluster is backed up.
- -e, --exclude-namespaces: excludes the backup of objects of a specified namespace. This parameter cannot be used together with --namespace.
- -x, --exclude-kind: excludes the backup of a specified resource type.
- -i, --include-kind: specifies the backup of a resource type.
- -y, --exclude-object: excludes the backup of a specified resource object.
- -z, --include-object: specifies the backup of a resource object.
- -w, --exclude-having-owner-ref: excludes the backup of resource objects with ownerReferences. The default value is false. The equal sign (=) must be contained in the parameter transfer process, for example, -w=true.
- -d, --local-dir: path for storing backup data. The default value is the k8clone-dump folder in the current directory.
$ ./k8clone-linux-amd64 backup -h Backup Workload Data as yaml files Usage: k8clone backup [flags] Flags: -s, --api-server string Kubernetes api-server url -q, --context string Kubernetes configuration context -w, --exclude-having-owner-ref Exclude all objects having an Owner Reference. The following form is not permitted for boolean flags such as '-w false', please use '-w=false' -x, --exclude-kind strings Resource kind to exclude. Eg. 'deployment' -i, --include-kind strings Ressource kind to include. Eg. 'deployment' -e, --exclude-namespaces strings Namespaces to exclude. Eg. 'temp.*' as regexes. This collects all namespaces and then filters them. Don't use it with the namespace flag. -y, --exclude-object strings Object to exclude. The form is '<kind>:<namespace>/<name>',namespace can be empty when object is not namespaced. Eg. 'configmap:kube-system/kube-dns' -z, --include-object strings Object to include. The form is '<kind>:<namespace>/<name>',namespace can be empty when object is not namespaced. Eg. 'configmap:kube-system/kube-dns' -h, --help help for backup -k, --kubeconfig string The kubeconfig of k8s cluster's. Default is the $HOME/.kube/config. -d, --local-dir string Where to dump yaml files (default "./k8clone-dump") -n, --namespace string Only dump objects from this namespace
Examples:
- Backs up objects of the entire cluster. The default path is the k8clone-dump folder in the current directory.
- Backs up objects of the entire cluster and specifies the path for storing backup data.
- Backs up objects of a specified namespace.
- Excludes the backup of objects of a specified namespace.
./k8clone-linux-amd64 backup -e kube-system,kube-public,kube-node-lease
- Excludes the backup of specified resource types.
- Specifies the backup of resource types.
- Excludes the backup of specified resource objects.
./k8clone-linux-amd64 backup -y configmap:kube-system/kube-dns
- Specifies the backup of resource objects.
./k8clone-linux-amd64 backup -z configmap:kube-system/kube-dns
- Excludes the backup of resource objects with ownerReferences.
k8clone Usage for Restoration
Run ./k8clone-linux-amd64 restore -h in the directory where k8clone is located to learn about its usage.
- -f, --restore-conf: path of restore.json. The default value is the directory where k8clone is located.
- -d, --local-dir: path for storing backup data. The default value is the directory where k8clone is located.
$ ./k8clone-linux-amd64 restore -h ProcessRestore from backup Usage: k8clone restore [flags] Flags: -s, --api-server string Kubernetes api-server url -q, --context string Kubernetes configuration context -h, --help help for restore -k, --kubeconfig string The kubeconfig of k8s cluster's. Default is the $HOME/.kube/config. -d, --local-dir string Where to restore (default "./k8clone-dump.zip") -f, --restore-conf string restore conf file (default "./restore.json")
Example:
