Updated on 2024-07-05 GMT+08:00
Configuring OBS Mount Options
This section describes how to configure OBS volume mount options. You can configure mount options in a PV and bind the PV to a PVC. Alternatively, configure mount options in a StorageClass and use the StorageClass to create a PVC. In this way, PVs can be dynamically created and inherit mount options configured in the StorageClass by default.
OBS Mount Options
When mounting an OBS volume, the Everest add-on presets the options described in Table 1 and Table 2 by default. The options in Table 1 are mandatory. You can set other mount options if needed. For details, see Mounting a Parallel File System.
Table 1 Mandatory mount options configured by default
Value
use_ino
Leave it blank.
If enabled, obsfs allocates the inode number. Enabled by default in read/write mode.
big_writes
Leave it blank.
If configured, the maximum size of the cache can be modified.
nonempty
Leave it blank.
Allows non-empty mount paths.
allow_other
Leave it blank.
Allows other users to access the parallel file system.
no_check_certificate
Leave it blank.
Disables server certificate verification.
sigv2
Leave it blank.
Specifies the signature version. Used by default in object buckets.
public_bucket
If this parameter is set to 1, public buckets are mounted anonymously. Enabled by default in object bucket read-only mode.
Table 2 Optional mount options configured by default
Value
max_write
131072
This parameter is valid only when big_writes is configured. The recommended value is 128 KB.
ssl_verify_hostname
0
Disables SSL certificate verification based on the host name.
max_background
100
Allows setting the maximum number of waiting requests in the background. Used by default in parallel file systems.
umask
0
Mask of the configuration file permission.
For example, if the umask value is 022, the directory permission (the maximum permission is 777) is 755 (777 – 022 = 755, rwxr-xr-x).
Configuring Mount Options in a PV
You can use the mountOptions field to configure mount options in a PV. The options you can configure in mountOptions are listed in OBS Mount Options.
  1. Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Configure mount options in a PV. Example:
    apiVersion: v1
    kind: PersistentVolume
      annotations:
        pv.kubernetes.io/provisioned-by: everest-csi-provisioner
        everest.io/reclaim-policy: retain-volume-only      # (Optional) The PV is deleted while the underlying volume is retained.
      name: pv-obs       # PV name.
      accessModes:
      - ReadWriteMany    # Access mode. The value must be ReadWriteMany for OBS.
      capacity:
        storage: 1Gi     # OBS volume capacity.
      csi:
        driver: obs.csi.everest.io        # Dependent storage driver for the mounting.
        fsType: obsfs                     # Instance type.
        volumeHandle: <your_volume_id>    # Name of the OBS volume.
        volumeAttributes:
          storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
          everest.io/obs-volume-type: STANDARD
          everest.io/region: <your_region>                        # Region where the OBS volume is located.
          everest.io/enterprise-project-id: <your_project_id>     # (Optional) Enterprise project ID. If an enterprise project is specified, use the same enterprise project when creating a PVC. Otherwise, the PVC cannot be bound to a PV.
        nodePublishSecretRef:            # Custom secret of the OBS volume.
          name: <your_secret_name>       # Custom secret name.
          namespace: <your_namespace>    # Namespace of the custom secret.
      persistentVolumeReclaimPolicy: Retain    # Reclaim policy.
      storageClassName: csi-obs               # Storage class name.
      mountOptions:                            # Mount options.
      - umask=027
  3. After a PV is created, you can create a PVC and bind it to the PV, and then mount the PV to the container in the workload. For details, see Using an Existing OBS Bucket Through a Static PV.
Configuring Mount Options in a StorageClass
You can use the mountOptions field to configure mount options in a StorageClass. The options you can configure in mountOptions are listed in OBS Mount Options.
  2. Create a customized StorageClass. Example:
    kind: StorageClass
    apiVersion: storage.k8s.io/v1
    provisioner: everest-csi-provisioner
    parameters:
      csi.storage.k8s.io/csi-driver-name: obs.csi.everest.io
      csi.storage.k8s.io/fstype: s3fs
    reclaimPolicy: Delete
    volumeBindingMode: Immediate
    - umask=027
  3. After the StorageClass is configured, you can use it to create a PVC. By default, the dynamically created PVs inherit the mount options configured in the StorageClass. For details, see Using an Existing OBS Bucket Through a Static PV.
