Help Center/ Cloud Container Engine/ User Guide/ User Guide for Autopilot Clusters/ Storage/ Object Storage Service/ Using a Custom Access Key (AK/SK) to Mount an OBS Volume
Updated on 2024-06-26 GMT+08:00
CCE supports custom access keys. In this way, IAM users can use their own custom access keys to mount an OBS volume. For details, see How Can I Control Access to OBS?
When an OBS volume is mounted using a custom access key (AK/SK), the access key cannot be deleted or disabled. Otherwise, the service container cannot access the mounted OBS volume.
Obtaining an Access Key
  2. Hover the cursor over the username in the upper right corner and choose My Credentials from the drop-down list.
  3. In the navigation pane, choose Access Keys.
  4. Click Create Access Key. The Create Access Key dialog box is displayed.
  5. Click OK to download the access key.
Creating a Secret Using an Access Key
  1. Obtain an access key.
  2. Encode the keys using Base64. (Assume that the AK is xxx and the SK is yyy.)
    echo -n xxx|base64
    echo -n yyy|base64
    Record the encoded AK and SK.
  3. Create a YAML file for the secret, for example, test-user.yaml.
    apiVersion: v1
    data:
      access.key: WE5WWVhVNU*****
      secret.key: Nnk4emJyZ0*****
    kind: Secret
      namespace: default
      labels:
        secret.kubernetes.io/used-by: csi
    type: cfe/secure-opaque
    Specifically:
    access.key
    Base64-encoded AK.
    secret.key
    Base64-encoded SK.
    name
    Secret name.
    namespace
    Namespace of the secret.
    Add this label in the YAML file if you want to make it available on the CCE console when you create an OBS PV/PVC.
    type
    Secret type. The value must be cfe/secure-opaque.
    When this type is used, the data entered by users is automatically encrypted.
  4. Create the secret.
    kubectl create -f test-user.yaml
Mounting a Secret When Statically Creating an OBS Volume
After a secret is created using the AK/SK, you can associate the secret with the PV to be created and then use the AK/SK in the secret to mount an OBS volume.
  1. Log in to the OBS console, create an OBS bucket, and record the bucket name and storage class. The parallel file system is used as an example.
  2. Create a YAML file for the PV, for example, pv-example.yaml.
    apiVersion: v1
    kind: PersistentVolume
      annotations:
        pv.kubernetes.io/provisioned-by: everest-csi-provisioner
      accessModes:
      - ReadWriteMany
      capacity:
        storage: 1Gi
      csi:
        nodePublishSecretRef:
          namespace: default
        driver: obs.csi.everest.io
        fsType: obsfs
        volumeAttributes:
          everest.io/obs-volume-type: STANDARD
          everest.io/region: ap-southeast-1
          storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner
        volumeHandle: obs-normal-static-pv
      persistentVolumeReclaimPolicy: Delete
      storageClassName: csi-obs
    Secret specified during the mounting.
    • name: name of the secret
    • namespace: namespace of the secret
    fsType
    File type. The value can be obsfs or s3fs. If the value is s3fs, an OBS bucket is created and mounted using s3fs. If the value is obsfs, an OBS parallel file system is created and mounted using obsfs. You are advised to set this field to obsfs.
    volumeHandle
    OBS bucket name.
  3. Create a PV.
    kubectl create -f pv-example.yaml
    After a PV is created, you can create a PVC and associate it with the PV.
  4. Create a YAML file for the PVC, for example, pvc-example.yaml.
    Example YAML file for the PVC:
    apiVersion: v1
    kind: PersistentVolumeClaim
      annotations:
        csi.storage.k8s.io/node-publish-secret-name: test-user
        csi.storage.k8s.io/node-publish-secret-namespace: default
        volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner
        csi.storage.k8s.io/fstype: obsfs
      namespace: default
      accessModes:
      - ReadWriteMany
      resources:
        requests:
          storage: 1Gi
      volumeName: pv-obs-example
    Name of the secret
  5. Create a PVC.
    kubectl create -f pvc-example.yaml
    After the PVC is created, you can create a workload and associate it with the PVC to create volumes.
Mounting a Secret When Dynamically Creating an OBS Volume
When dynamically creating an OBS volume, you can use the following method to specify a secret:
  1. Create a YAML file for the PVC, for example, pvc-example.yaml.
    apiVersion: v1
      annotations:
      namespace: default
      accessModes:
      - ReadWriteMany
      resources:
        requests:
          storage: 1Gi
    Name of the secret
  2. Create a PVC.
Verification
You can use a secret of an IAM user to mount an OBS volume. Assume that a workload named obs-secret is created, the mount path in the container is /temp, and the IAM user has the CCE ReadOnlyAccess and Tenant Guest permissions.
  1. Query the name of the workload pod.
    kubectl get po | grep obs-secret
    Expected outputs:
    obs-secret-5cd558f76f-vxslv          1/1     Running   0          3m22s
  2. Query the objects in the mount path. In this example, the query is successful.
    kubectl exec obs-secret-5cd558f76f-vxslv -- ls -l /temp/
  3. Write data into the mount path. In this example, the write operation failed.
    kubectl exec obs-secret-5cd558f76f-vxslv -- touch /temp/test
    Expected outputs:
    touch: setting times of '/temp/test': No such file or directory
    command terminated with exit code 1
  4. Set the read/write permissions for the IAM user who mounted the OBS volume by referring to the bucket policy configuration.
  5. Write data into the mount path again. In this example, the write operation succeeded.
  6. Check the mount path in the container to see whether the data is successfully written.
    Expected outputs:
    -rwxrwxrwx 1 root root 0 Jun  7 01:52 test
