Help Center/ Cloud Container Engine/ User Guide/ Permissions/ Workload Identity Authentication/ Using OIDC to Authenticate Workloads in a CCE Cluster
Updated on 2026-10-13 GMT+08:00
Workload identities enable workloads within a cluster to act as IAM users, granting them access to cloud services without the need for an IAM account's AK/SK. This helps minimize security risks.
This section describes how to use workload identities in a CCE cluster.
Notes and Constraints
The cluster version must be v1.19.16 or later.
  1. Obtain the signature public key of the cluster service account token from CCE. For details, see Step 1: Obtain the Signature Public Key of the CCE Cluster.
  2. Create an identity provider on IAM. For details, see Step 2: Configure an Identity Provider.
  3. Obtain an IAM token from the workload and simulate an IAM user to access a cloud service. For details, see Step 3: Use a Workload Identity.
    The figure below shows the workflow.
    Figure 1 Workflow
    1. Obtain the public key issued by the cluster and register the cluster token controller as an IAM identity provider.
      • The default identity provider of the clusters is https://kubernetes.default.svc.cluster.local.
      • If OIDC Provider is enabled in Overview > Connection Information of the cluster, you can obtain the identity provider URL in Service Account Issuer (service-account-issuer) in Settings > Kubernetes of the cluster.
    2. Request the service account to generate the corresponding OIDC token.
    3. Deploy the application pod and mount the OIDC token to it.
    4. Use the OIDC token to access IAM from the pod and obtain a temporary IAM token.
    5. Use the IAM token to access other cloud service resources from the pod.
  1. Use kubectl to access the cluster.
  2. Obtain the public key.
    kubectl get --raw /openid/v1/jwks
    The returned result is the public key of the cluster. The following is an example of the command output:
    # kubectl get --raw /openid/v1/jwks
    {"keys":[{"use":"sig","kty":"RSA","kid":"*****","alg":"RS256","n":"*****","e":"AQAB"}]}
  1. Log in to the IAM console. In the navigation pane, choose Identity Providers. In the right pane, click Create Identity Provider in the upper right corner. On the displayed page, set Protocol to OpenID Connect and SSO Type to Virtual user and click OK.
  2. In the identity provider list, locate the row containing the new identity provider, click Modify in the Operation column, and modify the identity provider information.
    Access Type: Select Programmatic access.
    Configuration Information
    • Identity Provider URL: The default identity provider of the cluster is https://kubernetes.default.svc.cluster.local.
    • Client ID: Enter a client ID, which will be used when you create a container.
      A client ID cannot contain only digits. If the client ID consists only of digits, enclose it in double quotation marks ("") when editing the YAML file for the workload. For example, if the client ID is 123456789, it should be entered as "123456789" in the YAML file.
    • Signing Key: Enter the JWKS of the CCE cluster obtained in Step 1: Obtain the Signature Public Key of the CCE Cluster.
    Identity Mapping Rules
    An identity mapping rule maps the service account of a workload to an IAM user.
    For example, create a service account named oidc-token in the default namespace of the cluster and map it to the demo user group. If you use the identity provider ID to access cloud services, you have the permissions of the demo user group. The attribute must be sub. The value is in the format of system:serviceaccount:Namespace:ServiceAccountName.
    Rules are in the JSON format as follows:
            "local": [
                    "user": {
                        "name": "test"
                    "group": {
                        "name": "demo"
            "remote": [
                    "type": "sub",
                    "any_one_of": [
                        "system:serviceaccount:default:oidc-token"
  3. Click OK.
  1. Create a service account. The name must be the value of ServiceAccountName set in Step 2: Configure an Identity Provider.
    apiVersion: v1
    kind: ServiceAccount
  2. Mount the service account token to the workload and obtain the OIDC token file.
    An example is as follows:
    apiVersion: apps/v1
    kind: Deployment
      replicas: 1
      selector:
        matchLabels:
          app: nginx
          version: v1
      template:
          labels:
            app: nginx
            version: v1
          containers:
          - name: container-1
            image: nginx:latest
            volumeMounts:
            - mountPath: "/var/run/secrets/tokens"     # Mount the Kubernetes-generated service account token to /var/run/secrets/tokens/oidc-token.
          imagePullSecrets:
          - name: default-secret
          serviceAccountName: oidc-token      # Name of the created service account
          volumes:
          - name: oidc-token
            projected:
              defaultMode: 420
              sources:
              - serviceAccountToken:
                  audience: client_id   # Must be the client ID of the identity provider.
                  expirationSeconds: 7200       # Expiration time
                  path: oidc-token              # Path name. You can change it as needed.
  3. After the creation is complete, log in to the container. The content of the /var/run/secrets/tokens/oidc-token file is the service account token generated by Kubernetes.
    If the service account token is valid for more than 24 hours or 80% of its expiration time, kubelet will automatically rotate the service account token.
  4. Use the OIDC token to call the API for Obtaining a Token with an OpenID Connect ID Token. The X-Subject-Token field in the response header is the IAM token. Then, you can use this token to access cloud services.
    The following shows an example:
    curl -iv --location --request POST 'https://{{iam endpoint}}/v3.0/OS-AUTH/id-token/tokens' \
     --header 'X-Idp-Id: workload_identity' \
     --header 'Content-Type: application/json' \
     --data @token_body.json
    Where:
    • {{iam endpoint}} indicates the endpoint of IAM. For details, see Regions and Endpoints.
    • workload_identity is the identity provider name, which is the same as that configured in Step 2: Configure an Identity Provider.
    • token_body.json is a local file and its content is as follows:
         "auth" : {
           "id_token" : {
             "id" : "eyJhbGciOiJSU..."
           "scope": {
             "project" : {
               "id" : "46419baef4324...",
               "name" : ******
      • $.auth.id_token.id: The value is the content of the /var/run/secrets/tokens/oidc-token file in the container.
      • $.auth.scope.project.id: indicates the project ID. To obtain the value, see Obtaining a Project ID.
      • $.auth.scope.project.name: indicates the project name, for example, cn-north-4.
