Pod Rescheduling by Partition
Function Introduction
During distributed AI training/inference in data centers, job instances have features like strong collaborative dependency, long-term running, and exclusive resource usage (such as NPUs and GPUs). However, data centers are prone to faults such as a node breakdown or network partition. If a cluster is faulty and affects the running of some pods, restarting the entire job is costly. As a result, the entire job may be stuck in a cycle of running, failure, and restart, and cannot be completed successfully. Migrating only the affected pods is less costly, but these pods may be isolated from other pods in the same group. This can cause outdated running information and invalid topology constraints. As a result, the entire group is in the state of occupying resources but not running properly, and cluster resources are wasted.
To address this issue, Volcano provides the capability of rescheduling pods by partition. When some pods are evicted or become inactive due to a cluster fault, the pods in the partition are proactively rescheduled to other suitable nodes to accelerate job recovery and avoid wasting cluster resources.
The following figure shows an example. The cluster consists of eight idle nodes, four tier-1 hypernodes, two tier-2 hypernodes, and one tier-3 hypernode. A Volcano job is running in the cluster. The job has two partitions. Each partition is scheduled to the same tier-1 hypernode. pod0 and pod1 are in partition1 and run on node0 and node1, respectively. pod2 and pod3 are in partition2 and run on node2 and node3, respectively. If node3 fails, pod3 on it becomes inactive.
- If pod rescheduling is not supported, the newly created pod3 will remain in the Pending state because no node meets the network topology constraints. As a result, pod2 occupies the resources of node2 but cannot run properly, wasting cluster resources. You can restart the entire job, but pod0 and pod1 will need to tbe restarted as well. This results in high job recovery costs.
- If pod rescheduling is supported, pod2 in the same partition can be proactively terminated, and the newly created pod2 and pod3 can be scheduled to node6 and node7 on hypernode3. In this way, the entire job can be efficiently restored.
Volcano provides the RestartPartition action in job lifecycle management policies, and pods in the entire partition can be restarted or rescheduled in case of a specific event. For example, add the following configuration to a job to restart and reschedule the entire partition when a pod in this partition is evicted or fails:
policies:
- action: RestartPartition
event: PodEvicted
event: PodFailed Prerequisites
The Volcano Scheduler add-on must be installed in the cluster, and the add-on version must be 1.21.1 or later.
- Network topology-aware scheduling does not support preemption. When resources are insufficient, the scheduler does not proactively preempt the resources that have been allocated to pods.
- If a group affinity policy is configured, network topology constraints in soft mode are not supported.
- Hyperjob workloads do not support network topology-aware scheduling. Even if networkTopology or group affinity policies are configured in the JobTemplate of a hyperjob, these configurations will be ignored and do not take effect.
- The hypernode auto discovery does not support clusters with multiple network topologies (for example, a cluster with both A2 and A3 topologies).
- You are advised not to change the network topology configuration items when the job is running. This is because such changes may cause the hypernode structure in the cluster to be rebuilt, which in turn may cause load fluctuations or scheduling exceptions in the Volcano Scheduler process.
- If the network topology structure or configuration items of a cluster are changed during scheduling, Volcano cannot ensure the correctness of the scheduling result.
Use Case
- In the navigation pane, choose Settings and click the Scheduling tab. Select Volcano, find the expert mode, and click Try Now.
- On the page for configuring the expert mode, modify default_controller_conf in the YAML file as follows to enable the hypernode auto discovery function: Configure the parameters based on your requirements.
... default_controller_conf: networkTopologyDiscovery: - source: label # Name of the hypernode auto discovery plugin, which cannot be changed enabled: true # Whether to enable the hypernode auto discovery plugin. true indicates that the plugin is enabled, and false indicates that the plugin is disabled (existing hypernode instances will not be deleted). config: networkTopologyTypes: testtopology: # Name of the network topology hierarchy. Up to 20 characters are allowed. Only one topology can be configured. - nodeLabel: test-tier-3 # Node label name corresponding to the tier-3 network topology. That means the hypernode tier is 3. - nodeLabel: test-tier-2 # Node label name corresponding to the tier-2 network topology. That means the hypernode tier is 2. - nodeLabel: test-tier-1 # Node label name corresponding to the tier-1 network topology. That means the hypernode tier is 1. - nodeLabel: kubernetes.io/hostname # Node label name corresponding to the tier-0 network topology (node level). The label name can only be matched based on the node name and cannot be modified. ... - Create eight nodes and add the network topology labels to them. The following figure shows the multi-tier network topology.
This example is for demonstration only. The hypernodes to be created must be based on the actual topology of the cluster. The nodes that are not in a network topology do not need network topology-related node labels. Otherwise, the created hypernodes may not meet the expectation.
kubectl label node 192.168.5.17 test-tier-3=HyperNode6 test-tier-2=HyperNode4 test-tier-1=HyperNode0 # node0 kubectl label node 192.168.5.224 test-tier-3=HyperNode6 test-tier-2=HyperNode4 test-tier-1=HyperNode0 # node1 kubectl label node 192.168.5.235 test-tier-3=HyperNode6 test-tier-2=HyperNode4 test-tier-1=HyperNode1 # node2 kubectl label node 192.168.5.239 test-tier-3=HyperNode6 test-tier-2=HyperNode4 test-tier-1=HyperNode1 # node3 kubectl label node 192.168.5.240 test-tier-3=HyperNode6 test-tier-2=HyperNode5 test-tier-1=HyperNode2 # node4 kubectl label node 192.168.5.251 test-tier-3=HyperNode6 test-tier-2=HyperNode5 test-tier-1=HyperNode2 # node5 kubectl label node 192.168.5.83 test-tier-3=HyperNode6 test-tier-2=HyperNode5 test-tier-1=HyperNode3 # node6 kubectl label node 192.168.5.95 test-tier-3=HyperNode6 test-tier-2=HyperNode5 test-tier-1=HyperNode3 # node7
Table 1 Mapping between nodes, IP addresses, and hypernodes Node Name
IP Address
Labels
node0
192.168.5.17
node1
192.168.5.224
node2
192.168.5.235
node3
192.168.5.239
node4
192.168.5.240
node5
192.168.5.251
node6
192.168.5.83
node7
192.168.5.95
- Query the hypernodes automatically discovered by Volcano.
kubectl get hypernodes
Information similar to the following is displayed:
NAME TIER TIERNAME NODECOUNT AGE hypernode-testtopology-tier1-2**** 1 test-tier-1 2 8s hypernode-testtopology-tier1-4**** 1 test-tier-1 2 8s hypernode-testtopology-tier1-j**** 1 test-tier-1 2 8s hypernode-testtopology-tier1-l**** 1 test-tier-1 2 8s hypernode-testtopology-tier2-m**** 2 test-tier-2 2 8s hypernode-testtopology-tier2-n**** 2 test-tier-2 2 8s hypernode-testtopology-tier3-c**** 3 test-tier-3 2 8s
- Create a Volcano job that requires four pods, with each pod exclusively occupying all NPU resources of a node. Configure a grouping policy to evenly divide the four pods into two partitions and schedule the pods in each partition to a hypernode whose tier is 1 at most. In addition, configure a lifecycle management policy with event set to PodEvicted and action set to RestartPartition, and enable the capability of rescheduling the pods in case of a fault. An example is provided as follows:
apiVersion: batch.volcano.sh/v1alpha1 kind: Job metadata: name: network-topology-job namespace: default spec: schedulerName: volcano policies: - action: RestartPartition # When a PodEvicted event occurs, all pods in the partition that the pods belong to are restarted. event: PodEvicted minAvailable: 4 # Gang scheduling condition. At least four pods must be successfully scheduled. tasks: - replicas: 4 # A total of four pods name: t0 partitionPolicy: # Configure a group affinity scheduling policy. totalPartitions: 2 # Split the task's pods into two partitions. partitionSize: 2 # Each partition contains two pods. networkTopology: # Configure network topology constraints at the partition level. mode: hard # The hard mode is used and must be met. highestTierAllowed: 1 # Allow placement on a tier=1 hypernode. template: spec: containers: - name: container1 image: nginx:latest resources: requests: huawei.com/ascend-1980: 16 # Each pod exclusively occupies the NPU resources of a single node. limits: huawei.com/ascend-1980: 16 - Check the scheduling result. Now, the first partition of pods has been scheduled to node0 and node1 of hypernode0, and the other group of pods has been scheduled to node2 and node3 of hypernode1.
kubectl get pod -o wide
NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES network-topology-job-t0-0 1/1 Running 0 6s 172.19.1.36 192.168.5.17 <none> <none> network-topology-job-t0-1 1/1 Running 0 6s 172.19.2.143 192.168.5.224 <none> <none> network-topology-job-t0-2 1/1 Running 0 6s 172.19.3.19 192.168.5.239 <none> <none> network-topology-job-t0-3 1/1 Running 0 6s 172.19.1.162 192.168.5.235 <none> <none>
- Evict the pod on node3 to simulate a node fault.
kubectl drain 192.168.5.239 --ignore-daemonsets
- Check the scheduling result again. The two pods in the second partition have been scheduled to node6 and node7 of hypernode3, maintaining the network topology consistency with other pods in the partitions.
NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES network-topology-job-t0-0 1/1 Running 0 2m51s 172.19.1.29 192.168.5.17 <none> <none> network-topology-job-t0-1 1/1 Running 0 2m51s 172.19.2.136 192.168.5.224 <none> <none> network-topology-job-t0-2 1/1 Running 0 80s 172.19.3.143 192.168.5.95 <none> <none> network-topology-job-t0-3 1/1 Running 0 82s 172.19.4.12 192.168.5.83 <none> <none>
- Restore node3.
kubectl uncordon 192.168.5.239
