Updated on 2026-08-13 GMT+08:00
Multi-dimensional and Multi-tier Network Topology-aware Scheduling
Background
In large-scale training jobs, it is common to split a big job into multiple shards, such as shards of model parallelism and replica groups of data parallelism. Compared with the communication between shards, each shard has higher requirements for the internal network communication performance.
In distributed inference tasks, there may also be subtasks with different roles, such as the common prefill and decode roles, and there are frequent communication between tasks of these roles.
In large model training or distributed inference scenarios, the entire training or inference task consumes a large number of resources, which cannot be met within a single network performance domain (hypernode). Although constrained network topology-aware scheduling for the entire task can ensure that the task is deployed in multiple specified network performance domains, it cannot ensure that each subtask is deployed in the same network performance domain. As a result, subtasks may be deployed across network performance domains, significantly affecting communication efficiency.
To address this, Volcano provides multi-dimensional and multi-tier network topology-aware affinity scheduling based on network topology-aware scheduling. During scheduling, Volcano detects the network topology of the cluster and preferentially schedules defined subtasks to the same network performance domain. This minimizes the internal communication overhead of subtasks while meeting the overall resource requirements of the task. This type of scheduling effectively addresses network communication performance issues in large-scale training and distributed inference jobs.
Function Introduction
Volcano provides a task grouping mechanism and allows you to configure independent network topology constraints for different groups based on the network topology constraints of the task.
After network topology-aware scheduling is enabled, the scheduler complies with both the network topology constraints of each subtask and the network topology constraints of the task. In this way, refined topology affinity scheduling for each subtask is implemented while meeting the overall network communication performance requirements of the job.
Volcano provides the capability of defining groups of pods within a task through the PodGroup resource object. By configuring the subGroupPolicy field, you can divide the pods in a PodGroup into multiple subgroups. In subGroupPolicy, network topology constraints can be independently configured for each subgroup. During scheduling, each subgroup complies with its own network topology constraints.
You can set subGroupPolicy for the associated PodGroups to implement multi-dimensional and multi-tier network topology-aware affinity scheduling for the task using Volcano. Volcano jobs and Kthena ModelServing workloads have built-in group definitions and network topology constraints. They can automatically create and manage PodGroups and comply with network topology constraints during scheduling.
apiVersion: scheduling.volcano.sh/v1beta1
kind: PodGroup
  namespace: default
  networkTopology:                           # Configure network topology constraints for PodGroups.
      mode: hard
      highestTierAllowed: 2
  subGroupPolicy:
  - name: subgroup-test
    subGroupSize: 2                          # Number of subgroup pods
    networkTopology:                         # Configure network topology constraints for subgroups.
      mode: hard
      highestTierAllowed: 1
    labelSelector:                           # Labels that pods in a group need to match
       matchLabels:
          task-type: test
    matchLabelKeys:                          # Criteria for grouping pods. Pods with the same value are grouped into the same subgroup.
    - group
Network Topology Constraint Configuration
In a Volcano job, you can configure the networkTopology field to describe the network topology constraints during job deployment. This ensures that job pods are scheduled to the optimal performance domain that meets the specified conditions, significantly improving computing efficiency and communication performance. The specific constraint configuration is as follows.
mode
There are two modes.
  • hard: a hard constraint requiring all pods within the job to be deployed on the same hypernode at a specified tier.
  • soft: a soft constraint where all pods in a job are deployed on the same hypernode at the lowest possible tier.
highestTierAllowed
This option is used with the hard mode and indicates the highest tier of hypernode to which a job can be deployed. It does not need to be configured in soft mode.
For example, if this parameter is set to 2, the job can be deployed only on hypernodes at tier 1 or tier 2. It cannot be deployed on hypernodes at tier 3 or higher.
  networkTopology:
    mode: hard
highestTierName
Used with the hard mode to specify the highest tier of hypernode allowed for job deployment. This field is not required in soft mode.
The Volcano Scheduler add-on must be installed in the cluster, and the add-on version must be 1.21.1 or later.
  • Network topology-aware scheduling does not support preemption. When resources are insufficient, the scheduler does not proactively preempt the resources that have been allocated to pods.
  • Hyperjob workloads do not support network topology-aware scheduling. Even if networkTopology or group affinity policies are configured in the JobTemplate of a hyperjob, these configurations will be ignored and do not take effect.
  • The hypernode auto discovery does not support clusters with multiple network topologies (for example, a cluster with both A2 and A3 topologies).
  • You are advised not to change the network topology configuration items when the job is running. This is because such changes may cause the hypernode structure in the cluster to be rebuilt, which in turn may cause load fluctuations or scheduling exceptions in the Volcano Scheduler process.
  • If the network topology structure or configuration items of a cluster are changed during scheduling, Volcano cannot ensure the correctness of the scheduling result.
Enabling Network Topology
  2. In the navigation pane, choose Settings and click the Scheduling tab. Select Volcano, find the expert mode, and click Try Now.
  3. Go to the expert mode page and enable the network-topology-aware add-on in the YAML file to implement network topology-aware scheduling.
    default_scheduler_conf:
      actions: allocate, backfill, preempt
      tiers:
      - plugins:
        - name: priority
        - enableJobStarving: false
          enablePreemptable: false
        - name: conformance
      - plugins:
        - enablePreemptable: false
        - name: predicates
        - name: nodeorder
      - plugins:
        - name: cce-gpu-topology-predicate
        - name: cce-gpu-topology-priority
        - name: xgpu
           name: network-topology-aware # Enable the network-topology-aware plugin.
      - plugins:
        - name: nodelocalvolume
        - name: nodeemptydirvolume
        - name: nodeCSIscheduling
        - name: networkresource
    Modify the default_controller_conf configuration to enable the hypernode auto discovery function. Configure other parameters based on your requirements.
    default_controller_conf:
      networkTopologyDiscovery:
        - source: label # Name of the hypernode auto discovery plugin, which cannot be changed
          enabled: true # Whether to enable the hypernode auto discovery plugin. true indicates that the plugin is enabled, and false indicates that the plugin is disabled (existing hypernode instances will not be deleted).
          config:
            networkTopologyTypes:
              testtopology:                        # Name of the network topology hierarchy. Up to 20 characters are allowed. Only one topology can be configured.
                - nodeLabel: test-tier-3            # Node label name corresponding to the tier-3 network topology. That means the hypernode tier is 3.
                - nodeLabel: test-tier-2            # Node label name corresponding to the tier-2 network topology. That means the hypernode tier is 2.
                - nodeLabel: test-tier-1            # Node label name corresponding to the tier-1 network topology. That means the hypernode tier is 1.
                - nodeLabel: kubernetes.io/hostname # Node label name corresponding to the tier-0 network topology (node level). The label name can only be matched based on the node name and cannot be modified.
    Click Save.
  4. Click Confirm Settings in the lower right corner. In the displayed dialog box, confirm the modification and click Save.
Implementing Multi-dimensional and Multi-tier Network Topology-aware Affinity Scheduling
To use multi-dimensional and multi-tier network topology-aware affinity scheduling, you need to define the hypernodes and network topology based on the cluster network environment. For details about how to define and generate hypernodes, see Network Topology-aware Scheduling.
The following example uses a two-tier network topology.
Example of Creating a Volcano Job
Volcano jobs use partitionPolicy to support job grouping definition and partition-level network topology constraints. Pods in a job can be divided into different partitions (for example, parallelism shards in a training job) based on pod labels, and independent network topology constraints can be specified for each partition. During scheduling, pods belonging to the same partition are scheduled to the same network performance domain that meets the topology constraints.
In this example, if task 1 in a job has eight replicas, you can use partitionPolicy to divide them into two partitions, with each partition containing four pods.
  • Pods in the same partition can only be scheduled to tier-1 hypernodes.
  • Pods in the same job can only be deployed on tier-2 or tier-1 hypernodes.
If tier-1 hypernodes cannot meet the resource scheduling requirements of a job, the scheduler can schedule different partitions to different tier-1 hypernodes under the same tier-2 hypernode. However, pods in the same partition must be deployed on the same tier-1 hypernode.
apiVersion: batch.volcano.sh/v1alpha1
kind: Job
  schedulerName: volcano
  networkTopology:                # Optional. Network topology constraints at the job level
    mode: hard                    # (Optional) Constraint mode
    highestTierAllowed: 2         # Optional. Highest hypernode tier at which a job can be deployed
  tasks:
    - name: "task"
      replicas: 8                 # Mandatory. The number of pods in a task
      partitionPolicy:           # Optional. All pods in the current task are grouped.
        totalPartitions: 2        # Mandatory. The number of partitions into which a group of pods in a task is divided
        partitionSize: 4          # Mandatory. The number of pods in each group (gang scheduling condition). The product of totalPartitions and partitionSize must be equal to the value of replicas.
        networkTopology:         # Optional. Network topology constraints for each group
          mode: hard              # (Optional) Used when configuring a group affinity policy
          highestTierAllowed: 1   # (Optional) Highest hypernode tier at which a partition can be deployed
      template:
          containers:
            - image: busybox
              command: ['sh', '-c', 'echo "Hello, Kubernetes!" && sleep 3600']
              imagePullPolicy: IfNotPresent
              resources:
                requests:
                  cpu: "1"
          restartPolicy: OnFailure
Example of Configuring Kthena ModelServing
In distributed inference workloads, there are two roles: prefill and decode. Multiple pods within the same role instance frequently communicate with each other. To improve communication efficiency, you must ensure that pods with the same role are deployed in the same network performance domain. Kthena's ModelServing allows you to define network topology-aware scheduling requirements for inference workloads in different dimensions. The system automatically creates and manages PodGroups based on ModelServing and uses Volcano to implement multi-dimensional and multi-tier network topology-aware affinity scheduling for workloads.
When creating a ModelServing workload, you only need to specify the network topology constraints in rolePolicy and groupPolicy. The ModelServing Controller automatically creates and manages the network topology constraints of PodGroups based on the network topology defined in rolePolicy and groupPolicy.
The hypernode tier in rolePolicy must not exceed that in groupPolicy. Otherwise, scheduling may fail.
apiVersion: workload.serving.volcano.sh/v1alpha1
kind: ModelServing
  namespace: default
  replicas: 1
  template:
    restartGracePeriodSeconds: 60
    networkTopology:
      rolePolicy:
        mode: hard              # Optional. Network topology constraint mode of the roles
        highestTierAllowed: 1   # (Optional) Highest hypernode tier at which pods with a role can be deployed
      groupPolicy:
        mode: hard              # Optional. Network topology constraint mode of the ServingGroup
        highestTierAllowed: 2   # Optional. Highest hypernode tier at which pods in a ServingGroup can be deployed
    roles:
      - name: prefill
        replicas: 1
        entryTemplate:
            containers:
              - name: leader
                image: busybox
                resources:
                  limits:
                    cpu: "0.5"
                  requests:
                    cpu: "0.5"
        workerReplicas: 3
        workerTemplate:
            containers:
              - name: worker
                image: busybox
                resources:
                  limits:
                    cpu: "0.5"
                  requests:
                    cpu: "0.5"
      - name: decode
        replicas: 1
        entryTemplate:
            containers:
              - name: leader
                image: busybox
                resources:
                  limits:
                    cpu: "0.5"
                  requests:
                    cpu: "0.5"
        workerReplicas: 3
        workerTemplate:
            containers:
              - name: worker
                image: busybox
                resources:
                  limits:
                    cpu: "0.5"
                  requests:
                    cpu: "0.5"
In this example, the inference workload consists of one prefill instance and one decode instance, which form a ServingGroup. Each instance contains four pods (one entry pod and three worker pods). During scheduling, pods in the prefill or decode instance can only be scheduled to nodes on the same tier-1 hypernode. Pods in the ServingGroup can be deployed on nodes on the same tier-2 hypernode.
