Configuring the GPU Driver Version Using a Node Label
If you need to configure a differentiated driver for a node, you can add a specific label to the node and define a driver policy in the ConfigMap to configure a custom refined node-level driver.
Ensure that CCE AI Suite (NVIDIA GPU) has been installed or upgraded to 2.13.1 or later.
- Install or edit CCE AI Suite (NVIDIA GPU) using YAML.
- In the navigation pane, choose Add-ons. In the right pane, find CCE AI Suite (NVIDIA GPU) and click Edit. Click Edit YAML.
If you install this add-on for the first time, find CCE AI Suite (NVIDIA GPU) in the right pane and click Install. Click Installation Using YAML.
- Edit the YAML file, add the following information to specify the node label name, and click Submit.
node_level_driver_label_name: <your-label-name>
For example, set the label name to gpu.type.
- Configure the node label.
- In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab.
- Locate the target node and choose More > Manage Labels in the Operation column.
- In the Manage Labels dialog box, click Add.
- Enter the label name (for example, gpu.type) set in 1 and a custom label value (for example, 535.216.03). Click OK.
- Create a custom driver download address for the specified label value.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Edit the ConfigMap in the kube-system namespace.
kubectl edit cm -n kube-system huawei-gpu-driver-config
- On the editing page, find the data field and add a new key-value pair in the following format:
custom_<label-value>: <driver-download-address>
In this example, the label value is 535.216.03. For details about the driver download address, see CCE AI Suite (NVIDIA GPU).
- Save the modification and exit the editor.
- Check whether the ConfigMap has been updated.
kubectl get cm -n kube-system huawei-gpu-driver-config -o yaml
Check whether the command output contains the custom_< label-value> field and the driver download address.
- Restart the node and check the new driver.
- Restart the node.
sudo reboot
- Log in to the node again after the node is restarted.
- Check whether the driver has been installed and is running normally.
nvidia-smi
Confirm that the driver version displayed in the command output is the target version.
+-----------------------------------------------------------------------------+ | NVIDIA-SMI 535.216.03 Driver Version: 535.216.03 CUDA Version: 12.2 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
- Restart the node.
