Updated on 2024-05-09 GMT+08:00
Comparison Between Cluster Types
Comparison
CCE provides different types of clusters for you to select. The following table lists the differences between them.
Category
Subcategory
CCE Standard
CCE Turbo
CCE Autopilot
Positioning
Standard clusters that provide highly reliable and secure containers for commercial use
Next-gen container cluster designed for Cloud Native 2.0, with accelerated computing, networking, and scheduling
Serverless clusters without user nodes and billed by actual CPU and memory usage
In such clusters, no node deployment, management, and security maintenance is needed.
Application scenario
For users who expect to use container clusters to manage applications, obtain elastic computing resources, and enable simplified management on computing, network, and storage resources
For users who have higher requirements on performance, resource utilization, and full-scenario coverage
For users whose services suffer frequent traffic surges, such as users in the online education and e-commerce sectors
Specification difference
Network model
Cloud native 1.0 network: applies to common, smaller-scale scenarios.
  • Tunnel network
  • Virtual Private Cloud (VPC) network
Cloud Native 2.0 network: applies to large-scale and high-performance scenarios.
Max networking scale: 2,000 nodes
Network performance
Overlays the VPC network with the container network, causing certain performance loss.
Flattens the VPC network and container network into one, achieving zero performance loss.
Network isolation
  • Tunnel network model: supports network policies for intra-cluster communications.
  • VPC network model: supports no isolation.
Associates pods with security groups. Unifies security isolation in and out the cluster via security groups' network policies.
Security isolation
Runs common containers, isolated by cgroups.
  • Physical machine: runs Kuasar containers, allowing VM-level isolation.
  • Runs common containers, isolated by cgroups.
VM-level isolation
Edge infrastructure management
None
Supports management of Intelligent EdgeSite (IES).
None
