Updated on 2025-09-23 GMT+08:00
Dashboard
The Dashboard tab provides basic cluster configuration information, including Cluster Information, Cluster Settings, and Installed Add-ons.
Navigation Path
  2. In the navigation pane, choose Cluster > Settings. Then click the Dashboard tab.
Cluster Information
It includes:
  • ID: uniquely identifies a cluster resource. It is automatically generated after a cluster is created and can be used in scenarios such as API calling.
  • Current Name: After a cluster is created, you can click to change its name.
  • Original Name: specifies a cluster's original name after its current name is changed. The current name of a cluster must be unique.
  • Status: specifies the status of the cluster. For details, see Cluster Lifecycle.
  • Type: This is a CCE Autopilot cluster.
  • Created On: specifies the time when a cluster was created. You will be billed based on the creation time of clusters.
Cluster Settings
After a cluster is created, you can view the following information:
  • Cluster Version | Patch Version: specifies the Kubernetes version and CCE patch version of the cluster.
  • Network Model: Only cloud native network 2.0 is supported.
  • Billing Mode: Only pay-per-use is supported.
  • Enterprise Project: specifies the enterprise project to which a cluster belongs. For details, see Enterprise Management.
  • Operation Protection: If operation protection is enabled, you need to confirm the operation through the virtual MFA device, SMS messages, or emails. You can go to the IAM console, choose Security Settings > Critical Operations, and enable operation protection.
  • Resource Tag: You can add resource tags to classify resources.
  • Cluster Description: specifies the description that you entered for a cluster. A maximum of 200 characters are allowed.
Installed Add-ons
This module allows you to view the add-ons installed in the cluster. If there are add-ons that can be upgraded in the cluster, click Go to Upgrade to view the add-ons on the Add-ons page. In the upper right corner, select All to view more details on the Add-ons page.
