Updated on 2025-07-17 GMT+08:00
Kubelet View
The kubelet is the agent that runs on each node in a cluster. The kubelet view allows you to monitor a cluster.
Metric Description
You can view kubelet metrics in the following table.
Table 1 Kubelet metrics
Metric
Unit
Running Kubelets
N/A
The number of running kubelets in a cluster.
Running Pods
N/A
The number of running pods on the node where the kubelet resides.
Running Containers
N/A
The number of running containers on the node where the kubelet resides.
Actual Volumes
N/A
The actual number of volumes on the node where the kubelet resides.
Expected Volumes
N/A
The desired number of volumes on the node where the kubelet resides.
Configuration Errors
N/A
The number of incorrect Kubelet configurations on the node where the kubelet resides.
Operation Rate
N/A
The number of operations performed by the kubelet per second.
Operation Error Rate
N/A
The number of failed operations performed by the kubelet per second.
Operation Latency
second
The latencies of operations performed by the kubelet.
Pod Startup Rate
N/A
The number of pod startups performed by the kubelet per second.
Pod Startup Latency (P99)
second
The P99 latencies of pod startups performed by the kubelet.
Storage Operation Rate
N/A
The number of storage-related operations performed by the kubelet per second.
Storage Operation Error Rate
N/A
The number of failed storage-related operations performed by the kubelet per second.
Storage Operation Latency (P99)
second
The P99 latencies of storage-related operations performed by the kubelet.
Cgroup Manager Operation Rate
N/A
The number of destroy or update operations performed by the kubelet per second.
Cgroup Manager Operation Latency (P99)
second
The P99 latencies of destroy or update operations performed by the kubelet.
PLEG Relist Rate
N/A
The number of relisting operations in PLEG per second.
PLEG Relist Interval (P99)
second
The intervals between 99% of relisting operations in PLEG.
PLEG Relist Latency (P99)
second
The P99 latencies of relisting operations in PLEG.
RPC Rate
N/A
The number of RPC requests with each status code.
Request Latency (P99)
second
The P99 latencies of requests with each method.
Used Memory
byte
The memory used by the kubelet.
Used CPU
byte
The CPU used by the kubelet.
Goroutines
N/A
The number of goroutines.
Metric List
The following is the metric list of the kubelet view.
Table 2 Metric description
Metric
Type
storage_operation_errors_total
Counter
The number of errors in storage operations.
storage_operation_duration_seconds_count
Counter
The number of storage operations.
storage_operation_duration_seconds_bucket
Histogram
Duration for each storage operation.
kubelet_pod_start_duration_seconds_count
Counter
The number of pods that have been started.
kubelet_pod_start_duration_seconds_bucket
Histogram
Duration from the kubelet seeing a pod for the first time to the pod starting to run.
kubelet_runtime_operations_duration_seconds_bucket
Histogram
The time of every operation.
kubelet_runtime_operations_errors_total
Counter
The number of errors in operations at runtime level.
kubelet_node_config_error
Gauge
If a configuration-related error occurs on a node, the value of this metric is true (1). If there is no configuration-related error, the value is false (0).
volume_manager_total_volumes
Gauge
The number of volumes in Volume Manager.
kubelet_running_containers
Gauge
The number of running containers.
kubelet_running_pods
Gauge
The number of running pods.
kubelet_node_name
Gauge
Node name. The value is always 1.
kubelet_runtime_operations_total
Counter
The number of total runtime operations of each type.
kubelet_cgroup_manager_duration_seconds_count
Counter
The number of destruction and update operations.
kubelet_cgroup_manager_duration_seconds_bucket
Histogram
Duration for destruction and update operations.
kubelet_pleg_relist_duration_seconds_count
Counter
The number of relisting operations in PLEG.
kubelet_pleg_relist_interval_seconds_bucket
Histogram
The intervals between relisting operations in PLEG.
kubelet_pleg_relist_duration_seconds_bucket
Histogram
Duration for relisting pods in PLEG.
rest_client_requests_total
Counter
The total number of HTTP requests, partitioned by status code and method.
rest_client_request_duration_seconds_bucket
Histogram
The number of HTTP requests, partitioned by status code and method.
process_resident_memory_bytes
Gauge
Resident memory size in bytes.
process_cpu_seconds_total
Counter
Total user and system CPU time spent in seconds.
go_goroutines
Gauge
