Before You Start
Before the upgrade, you can check whether your cluster can be upgraded and which versions are available on the CCE console. For details, see Upgrade Overview.
Precautions
- Perform the upgrade during off-peak hours to minimize the impact on your services.
- Before the upgrade, learn about the features and differences of each cluster version in Kubernetes Version Release Notes to prevent exceptions due to the use of an incompatible cluster version. For example, check whether any APIs deprecated in the target version are used in the cluster. Otherwise, API calls may fail after the upgrade.
- Do not upgrade a cluster within 10 minutes after the cluster configuration is modified on the Settings page. Otherwise, the cluster upgrade may fail due to operation conflicts.
- There are no high-risk operations performed in the cluster. If there are high-risk operations, the cluster upgrade may fail or the configuration may be lost after the upgrade. For example, modifying the configuration of a listener configured for CCE on the ELB console is a high-risk operation. It is recommended that you modify configurations on the CCE console so that the modifications can be automatically inherited during the upgrade.
If an error occurs during a cluster upgrade, the cluster can be rolled back using the backup data. If you perform other operations (for example, modifying cluster specifications) after a successful cluster upgrade, the cluster can be rolled back using the backup data.
Deprecated APIs
With the evolution of Kubernetes APIs, APIs are periodically reorganized or upgraded, and old APIs are deprecated and finally deleted. For details about deprecated APIs, see Deprecated API Migration Guide.
When an API is deprecated, the existing resources are not affected. However, when you create or edit the resources, the API version will be intercepted.
Upgrade Backup
How to back up a node:
| Backup Method | Backup Object | Backup Type | Backup Time | Rollback Time | Description |
| etcd data backup | etcd data | Automatic backup during the upgrade | 1–5 minutes | 2 hours | Mandatory. The backup is automatically performed during the upgrade. |
| EVS snapshot backup | Control plane details, including component images, configurations, logs, and etcd data | One-click backup on web pages (manually triggered) | 1–5 minutes | 20 minutes | - |
