Updated on 2026-09-28 GMT+08:00
Upgrade Overview
CCE Autopilot strictly complies with community consistency authentication. It releases three cluster versions each year and offers a maintenance period of at least 24 months after each version is released. CCE Autopilot ensures the stable running of cluster versions during the maintenance period.
To ensure your service rights and benefits, upgrade your Kubernetes clusters before a maintenance period ends. Proactive cluster upgrades help you:
  • Reduce security and stability risks: During the iteration of Kubernetes versions, known security and stability vulnerabilities are continuously fixed. Long-term use of EOS clusters will result in security and stability risks to services.
  • Experience the latest functions: During the iteration of Kubernetes versions, new functions and optimizations are continuously released.
  • Minimize compatibility risks: During the iteration of Kubernetes versions, APIs are continuously modified and functions are deprecated. If a cluster has not been upgraded for a long time, more O&M assurance investment will be required when the cluster is upgraded. Periodic upgrades can effectively mitigate compatibility risks caused by accumulated version differences. It is a good practice to upgrade a patch version every quarter and upgrade a major version to the latest version every year.
  • Obtain more effective technical support: CCE does not provide security patches or issue fixes for EOS Kubernetes cluster versions, and does not ensure technical support for the EOS versions.
You can check Kubernetes cluster versions on the cluster list page and view if there is a new version for a cluster to upgrade. If necessary, obtain the expert consultation service.
Cluster Upgrade Paths
CCE Autopilot clusters evolve iteratively based on the community Kubernetes version. A CCE cluster version consists of the community Kubernetes version and the patch version, so two cluster upgrade paths are provided.
  • Kubernetes version
    Source Kubernetes Version
    Target Kubernetes Version
    v1.28
    v1.31
    v1.31
    v1.32 or v1.34
    v1.32
    v1.34
    v1.34
    v1.35
    v1.35
    v1.36
    v1.36
    N/A
    A Kubernetes version can be upgraded only after the patch is upgraded to the latest version. CCE will automatically generate an optimal upgrade path on the console based on the current cluster version.
  • Patch version
    Patch version management is available for CCE Autopilot clusters to provide new features and fix bugs and vulnerabilities for in-maintenance clusters without requiring a major version upgrade.
    After a new patch version is released, you can upgrade to the latest patch version at any time.
Cluster Upgrade Process
The cluster upgrade process involves pre-upgrade check, backup, upgrade, and post-upgrade verification.
Figure 1 Cluster upgrade process
After determining the target version of the cluster, read the precautions carefully and prevent function incompatibility during the upgrade.
  1. Pre-upgrade check
    Before a cluster upgrade, mandatory items such as the cluster status, add-ons, and workloads are automatically checked to ensure that the cluster meets the upgrade requirements. For more details, see Troubleshooting for Pre-upgrade Check Exceptions. If any check item is abnormal, rectify the fault on the console as prompted.
  2. Backup
    You can use disk snapshots to back up the control plane details such as cluster component images, component configurations, and etcd data. Back up your data before an upgrade. If unexpected cases occur during an upgrade, you can use the backup to quickly restore the cluster.
    Backup Method
    Backup Object
    Backup Type
    Backup Time
    Rollback Time
    etcd data backup
    etcd data
    Automatic backup during the upgrade
    1–5 minutes
    2 hours
    Mandatory. The backup is automatically performed during the upgrade.
    EVS snapshot backup
    Control plane details, including component images, configurations, logs, and etcd data
    One-click backup on web pages (manually triggered)
    1–5 minutes
    20 minutes
  3. Configuration and upgrade
    Parameters need to be configured before an upgrade. CCE Autopilot has provided default settings, which can be modified as needed. After the configuration, the add-ons, control plane, and data plane will be upgraded in sequence.
    • Add-on Upgrade Configuration: Add-ons that have been installed in your cluster are listed. During a cluster upgrade, CCE automatically upgrades the selected add-ons to be compatible with the target cluster version. You can click Set to re-define the add-on parameters.
      If an add-on is marked with on its right side, the add-on cannot be compatible with both the source and target versions of the cluster upgrade. In this case, CCE will upgrade the add-on after the cluster upgrade. The add-on may be unavailable during the cluster upgrade.
  4. Post-upgrade verification
    After an upgrade, CCE Autopilot will automatically check items such as the cluster status. You need to manually check services and new pods to ensure that the cluster functions properly after the upgrade.
Helpful Links
