Creating an Organizational Replication Policy
As cross-region and cross-department business collaboration deepens, efficient and secure data transfer between regions and organizations becomes a key pain point. You can create an organizational replication policy to flexibly replicate data across regions and organizations, effectively solving problems such as scattered enterprise data and difficulty to meet compliance requirements in multiple regions.
For example, if an enterprise has branches in different regions, the enterprise administrator can create an organizational replication policy to back up the production data of each branch and replicate the data to the vault in the specified region at the headquarters at a specified time every day. This makes data analysis and monitoring more convenient. Multinational Internet enterprises can customize replication policies for service departments in different regions to replicate service data to compliant regions, meeting the local data storage requirements of different countries.
The organizational administrator or delegated administrator can create an organizational replication policy on the CBR console and set parameters such as the replication time and interval. If this organizational replication policy is applied to a vault in an organization, the system automatically replicates resources of the member accounts at the specified time based on the policy.
This section describes how to create an organizational replication policy.
- You can set replication policies for server backup vaults and SFS Turbo backup vaults.
- A maximum of 64 organizational replication policies can be created in each account.
- Log in to the CBR console. Click
in the upper left corner and select a region. - Choose Organizational Policies in the navigation pane and click the Organizational Replication Policies tab. In the upper right corner, click Create Organizational Policy. Select Replication for Organizational Policy Type. Figure 1 Creating an organizational policy
- Set the replication policy parameters. Table 1 describes the parameters.
Table 1 Replication policy parameters Parameter
Example Value
Organizational Policy Name
Organizational policy name.
The name can contain 1 to 64 characters. Only letters, digits, underscores (_), and hyphens (-) are allowed.
org_policy
Organizational Policy Description
Description that can help the organization members to understand the usage of the policy.
Select a policy type. In this section, select Replication.
Replication
Policy Name
Replication policy name. You can enter a custom name or use the default name policy_xxxx.
replication_policy
Status
Whether to enable the replication policy. By default, this function is enabled.
CBR replicates backups and deletes expired replicas only after a replication policy is enabled and applied to vaults.
Enabled
Replication Frequency
Select a replication frequency. By default, the replication task is executed automatically every Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, and Sunday.
- Weekly
Specifies on which days of each week the replication task will be executed. You can select multiple days.
- Day-based
Specifies the interval (every 1 to 30 days) for executing the replication task.
If you select day-based replication, the first replication is supposed to be executed on the day when the replication policy is created. If the replication policy is created after the replication time, the first replication will be executed in the next replication period.
Every day
Execution Time
Execution times of the replication policy in a day. The default replication time is 22:00.
Replication tasks can be scheduled at the beginning of each hour, and you can select multiple hours.
It is recommended that replication be performed during off-peak hours or when no services are running.
00:00, 02:00
Destination Region
Select the region to which the backup data is to be replicated.
Only the regions that support replication will be displayed. For details about the regions that support cross-region replication, see Table 1.
- If the selected region contains only one project, you can directly select the region name.
- If the selected region has multiple projects, the default project of the region is preselected, but you can still select another project if needed.
AP-Bangkok
Retention Rule
Rule that specifies how backup replicas will be retained in the destination region. By default, backup replicas are retained for one month.
- Backup quantity
You can set the maximum number of backup replicas to retain for each resource. The value ranges from 2 to 99,999.
You can also set long-term retention rules with advanced options. Long-term retention rules and quantity-based retention rules will be both applied.
- Day-based: 0–100
- Weekly: 0–100
- Monthly: 0–100
- Yearly: 0–100
A resource may be replicated multiple times in a day. If day-based replication is configured, only the most recent backup replica of that day is retained. If you set Day-based to 5, the most recent backup replica of each of the last five days that have backups generated will be retained and the earliest backup replicas will be deleted automatically. When multiple backup schedules (daily, weekly, monthly, yearly) are enabled, the system retains the combined union of all backups. For example, if Day-based is set to 5 and Weekly to 1, five backup replicas will be retained. The long-term retention rule and the quantity-based retention rule both apply.
- Time period
Backups can be retained for one month, three months, six months, one year, or a user-defined period between 2 and 99,999 days.
- Permanent NOTE:
- The system automatically deletes the earliest and expired backup replicas every other day. This prevents exceeding the maximum number of backup replicas to retain or retaining any backup replica longer than the maximum retention period.
- CBR may experience delays in deleting expired backup replicas, but these delays will not exceed 24 hours.
- The retention rules apply only to auto-generated backup replicas, but not manually-created ones. Manually-created backup replicas must be deleted manually from the backup list in the destination region.
- After a backup replica is used to create an image or a file system, it is excluded from the retention count and will not be automatically deleted.
6 months
- Weekly
- Click Create Now.
After the replication policy is created, it will automatically appear in each member account's policy list. Users with the member accounts can view the created policies in Organizational Policies on the CBR console.
Follow-Up Operations
