Help Center/
Cloud Application Engine/
User Guide/
Component Management/
Managing Components/
Stopping a Component
Updated on 2025-11-13 GMT+08:00
You can stop a component that is not used. After a component is stopped, no fee is generated and its associated applications cannot be used.
- Components in the Not deployed and Not ready states cannot be stopped.
- Do not stop a component when it is being scaled. Disable the AS policy before the operation. For details, see Disabling an AS Policy.
- When a component is being stopped, AS policies cannot be added or enabled for the component.
- Log in to CAE.
- Choose Components.
- Select the target component and click More > Stop in the Operation column.
Figure 1 Stopping a component
Parent topic: Managing Components
