Viewing BMS Details
After you obtain a BMS, you can view and manage your BMS on the management console. This section describes how to view BMS details, including the BMS name/ID, EIPs, disks, and NICs.
- Log in to the BMS console.
- In the upper right corner of the BMS list, query BMSs by specifying the project, status, name, BMS ID, flavor, and private IP address. Alternatively, click Search by Tag above the upper right corner of the BMS list and search for a BMS by tag key and value. Figure 1 Searching BMSs
- Click the name of the queried BMS.
- View the BMS details, such as name, status, flavor, and VPC. You can also click the Disks, NICs, Security Groups, EIPs, Tag, and Monitoring tabs to attach EVS disks to or detach EVS disks from the BMS, change the security group, bind an EIP to or unbind an EIP from the BMS, and create agencies.
The BMS monitoring data and charts are not displayed on the BMS details page. You need to view them on the Cloud Eye console. The prerequisite is that Agent has been installed on your BMS. For details, see Overview.
