Exporting the BMS List
The list of all BMSs under your account can be exported to a local .xlsx file. The file is named in the format BMS-Region-Current date. It contains information such as the BMS name, ID, AZ, status, and specifications.
- Log in to the BMS console.
- Above the BMS list, click Export.
The system will automatically export the list of all BMSs in the current region under your account to a local file.
- In the default download directory of your computer, check the exported list.
