Updated on 2026-01-13 GMT+08:00
Metadata Security
Disabling BMS Metadata (When Purchasing a BMS)
If your BMS applications do not need to access metadata, disable metadata to avoid security risks.
  1. Log in to the BMS console and access the Buy BMS page.
  2. In Advanced Settings, set Metadata Access to Disable.
    Figure 1 Disabling metadata access
  3. Check the settings and click Next: Confirm. Complete the BMS creation.
Disabling Instance Metadata (for an Existing BMS)
  2. Click the name of a BMS to go to its details page.
  3. Disable metadata access.
    Figure 2 Disabling metadata access
  4. In the Disable Metadata Access dialog box, enter YES and click OK.
    Figure 3 Disabling metadata access
Restricting the Scope of an Agency
Configure an agency to obtain temporary credentials from metadata. For details, see Accessing Other Cloud Services from ECS Using Temporary Access Keys of an Agency.
To prevent credential leakage, you need to strictly control the scope of the agency.
  • If temporary credentials are not required, do not configure an agency.
  • If temporary credentials are required, configure only necessary permissions for the agency based on the principle of least privilege (PoLP).
Accessing Metadata Using V2 (Hardening)
V2 (hardening) helps prevent most SSRF attacks on metadata.
However, this denies access using the V1 (traditional) method. To prevent this issue, use V2 (hardening) at the instance level.
  • Set the access method of services or applications in the OS to V2 (hardening) for metadata access.
  • Set Metadata Version of a BMS to Only V2 (Token). For details, see Configuring Instance Metadata Options.
Using a Firewall to Restrict Access to Metadata
If metadata contains sensitive data, use local firewall rules to restrict access to metadata at the OS user level.
Example firewall configuration:
  • Windows
    To only allow the administrator to access custom data, enable the firewall as the administrator and run the following commands in PowerShell:
    PS C:\>$RejectPrincipal = New-Object -TypeName System.Security.Principal.NTAccount ("Everyone")
    PS C:\>$RejectPrincipalSID = $RejectPrincipal.Translate([System.Security.Principal.SecurityIdentifier]).Value
    PS C:\>$ExceptPrincipal = New-Object -TypeName System.Security.Principal.NTAccount ("Administrator")
    PS C:\>$ExceptPrincipalSID = $ExceptPrincipal.Translate([System.Security.Principal.SecurityIdentifier]).Value
    PS C:\>$PrincipalSDDL = "O:LSD:(D;;CC;;;$ExceptPrincipalSID)(A;;CC;;;$RejectPrincipalSID)"
    PS C:\>New-NetFirewallRule -DisplayName "Reject metadata service for $($RejectPrincipal.Value), exception: $($ExceptPrincipal.Value)" -Action block -Direction out -Protocol TCP -RemoteAddress 169.254.169.254 -LocalUser $PrincipalSDDL
  • Linux
    To only allow user root to access custom data, run the following command as user root:
    iptables --append OUTPUT --proto tcp --destination 169.254.169.254 --match owner ! --uid-owner root --jump REJECT
