Help Center/ Bare Metal Server/ User Guide/ Instances/ User Data and Metadata/ Obtaining BMS Details Using Metadata
Updated on 2026-07-29 GMT+08:00
Introduction
The BMS metadata includes BMS basic information on the cloud platform, such as the BMS ID, hostname, and network information. The BMS metadata can be retrieved using compatible OpenStack and EC2 APIs listed in Table 1.
Table 1 BMS metadata types
Metadata Type
Metadata Item
OpenStack type
/meta_data.json
This interface is used to query BMS metadata.
For the key fields in the BMS metadata, see Table 2.
/password
This interface is used to query the BMS password.
If a key pair is selected during the creation of a Windows BMS, Cloudbase-Init is used to save the ciphertext password when the BMS is initialized.
/user_data
This interface is used to query BMS user data.
This metadata allows you to specify scripts and configuration files for initializing BMSs. For details, see Configuring a BMS by Injecting User Data.
For password-authenticated Linux BMSs, save the password injection script.
/network_data.json
This interface is used to query network information of a BMS.
/securitykey
This interface is used to obtain temporary security credentials: Access Key ID (AK) and Secret Access Key (SK).
Before obtaining temporary AK/SK on a BMS, you need to create an agency for BMS on IAM and assign required resource permissions to BMS.
EC2 type
/meta-data/hostname
This interface is used to query the host name of a BMS.
To remove the suffix .novalocal from a BMS, see:
Is the BMS Host Name with Suffix novalocal Normal?
/meta-data/instance-type
This interface is used to query the flavor name of a BMS.
/meta-data/local-ipv4
This interface is used to query the fixed IP address of a BMS.
If there are multiple NICs, only the IP address of the primary NIC is displayed.
/meta-data/placement/availability-zone
This interface is used to query AZ information about a BMS.
/meta-data/public-ipv4
This interface is used to query the EIP of a BMS.
If there are multiple NICs, only the EIP of the primary NIC is displayed.
/meta-data/public-keys/0/openssh-key
This interface is used to query the public key of a BMS.
/user-data
/meta-data/security-groups
This interface is used to query the name of the security group of the BMS.
Table 2 Metadata key fields
Type
uuid
String
Specifies the BMS ID.
availability_zone
String
Specifies the AZ where the BMS is located.
meta
Dict
Specifies the metadata information, including the image name, image ID, and VPC ID.
hostname
String
Specifies the hostname of the BMS.
vpc_id
String
Specifies the ID of the VPC where the BMS is located.
The following describes the URI and methods of using the supported BMS metadata.
  • You have logged in to the BMS.
  • Security group rules in the outbound direction meet the following requirements:
    • Protocol: TCP
    • Port Range: 80
    • Remote End: 169.254.0.0/16
    If you use the default security group rules in the outbound direction, the preceding requirements are met, and the metadata can be accessed. The default outbound security group rule is as follows:
    • Protocol: Any
    • Port Range: Any
    • Remote End: 0.0.0.0/16
Metadata (OpenStack Metadata API)
  • URI
    /169.254.169.254/openstack/latest/meta_data.json
  • Method
    Supports GET requests.
  • Example
    The following describes how to use the cURL tool to query the BMS metadata:
    curl http://169.254.169.254/openstack/latest/meta_data.json
        "random_seed": "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",
        "uuid": "ca9e8b7c-f2be-4b6d-a639-f10b4d994d04",
        "availability_zone": "lt-test-1c",
        "hostname": "bms-ddd4-l00349281.novalocal",
        "launch_index": 0,
        "meta": {
            "metering.image_id": "3a64bd37-955e-40cd-ab9e-129db56bc05d",
            "metering.imagetype": "gold",
            "metering.resourcespeccode": "physical.s3.small",
            "metering.cloudServiceType": "service.type.ec2",
            "image_name": "CentOS 7.6 64bit",
            "os_bit": "64",
            "vpc_id": "3b6c201f-aeb3-4bce-b841-64756e66cb49",
            "metering.resourcetype": "1",
            "cascaded.instance_extrainfo": "pcibridge:2",
            "os_type": "Linux",
            "charging_mode": "0"
        "project_id": "6e8b0c94265645f39c5abbe63c4113c6",
        "name": "ecs-ddd4-l00349281"
User Data (OpenStack Metadata API)
This interface is used to query BMS user data. The value is configured when you create a BMS. It cannot be changed after the configuration.
  • URI
    /169.254.169.254/openstack/latest/user_data
  • Method
  • Example
    curl http://169.254.169.254/openstack/latest/user_data
    ICAgICAgDQoiQSBjbG91ZCBkb2VzIG5vdCBrbm93IHdoeSBpdCBtb3ZlcyBpbiBqdXN0IHN1Y2ggYSBkaXJlY3Rpb24gYW5kIGF0IHN1Y2ggYSBzcGVlZC4uLkl0IGZlZWxzIGFuIGltcHVsc2lvbi4uLnRoaXMgaXMgdGhlIHBsYWNlIHRvIGdvIG5vdy4gQnV0IHRoZSBza3kga25vd3MgdGhlIHJlYXNvbnMgYW5kIHRoZSBwYXR0ZXJucyBiZWhpbmQgYWxsIGNsb3VkcywgYW5kIHlvdSB3aWxsIGtub3csIHRvbywgd2hlbiB5b3UgbGlmdCB5b3Vyc2VsZiBoaWdoIGVub3VnaCB0byBzZWUgYmV5b25kIGhvcml6b25zLiINCg0KLVJpY2hhcmQgQmFjaA==
    If user data is not injected during BMS creation, the query result is 404.
    Figure 1 404 Not Found
Network Data (OpenStack Metadata API)
  • URI
    /openstack/latest/network_data.json
  • Method
  • Example
    curl http://169.254.169.254/openstack/latest/network_data.json
        "services": [{
            "type": "dns",
            "address": "100.125.1.250"
            "type": "dns",
            "address": "100.125.21.250"
        "networks": [{
            "network_id": "67dc10ce-441f-4592-9a80-cc709f6436e7",
            "type": "ipv4_dhcp",
            "link": "tap68a9272d-71",
            "id": "network0"
        "links": [{
            "type": "cascading",
            "vif_id": "68a9272d-7152-4ae7-a138-3ef53af669e7",
            "ethernet_mac_address": "fa:16:3e:f7:c1:47",
            "id": "tap68a9272d-71",
            "mtu": null
Security Key (OpenStack Metadata API)
  • To obtain temporary AK/SK on a BMS, you need to create an agency for BMS on IAM and assign required resource permissions to BMS. For details, see Identity and Access Management User Guide.
  • The temporary AK/SK pair expires an hour later but is updated 10 minutes ahead of the expiration time. During the 10 minutes, both the new and old temporary AK/SK pairs can be used.
  • When using temporary AK/SK, add 'X-Security-Token':securitytoken in the message header. securitytoken is the value returned when a call is made to the API.
  • URI
    /openstack/latest/securitykey
  • Method
  • Example
    curl http://169.254.169.254/openstack/latest/securitykey
User Data (EC2 Compatible API)
  • URI
    /169.254.169.254/latest/user-data
  • Method
  • Example
    curl http://169.254.169.254/latest/user-data
Hostname (EC2 Compatible API)
This interface is used to query the name of the host accommodating a BMS. The .novalocal suffix will be added later.
  • URI
    /169.254.169.254/latest/meta-data/hostname
  • Method
  • Example
    curl http://169.254.169.254/latest/meta-data/hostname
    bms-test.novalocal
Instance Type (EC2 Compatible API)
  • URI
    /169.254.169.254/latest/meta-data/instance-type
  • Method
  • Example
    curl http://169.254.169.254/latest/meta-data/instance-type
    physical.i7n.28xlarge.4
Local IPv4 (EC2 Compatible API)
This interface is used to query the fixed IP address of a BMS. If there are multiple NICs, only the IP address of the primary NIC is displayed.
  • URI
    /169.254.169.254/latest/meta-data/local-ipv4
  • Method
  • Example
    curl http://169.254.169.254/latest/meta-data/local-ipv4
    192.1.1.2
Availability Zone (EC2 Compatible API)
  • URI
    /169.254.169.254/latest/meta-data/placement/availability-zone
  • Method
  • Example
    curl http://169.254.169.254/latest/meta-data/placement/availability-zone
    az1.dc1
Public IPv4 (EC2 Compatible API)
This interface is used to query the EIP of a BMS. If there are multiple NICs, only the EIP of the primary NIC is displayed.
  • URI
    /169.254.169.254/latest/meta-data/public-ipv4
  • Method
  • Example
    curl http://169.254.169.254/latest/meta-data/public-ipv4
    46.1.1.2
Public Keys (EC2 Compatible API)
  • URI
    /169.254.169.254/latest/meta-data/public-keys/0/openssh-key
  • Method
  • Example
    curl http://169.254.169.254/latest/meta-data/public-keys/0/openssh-key
    ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDI5Fw5k8Fgzajn1zJwLoV3+wMP+6CyvsSiIc/hioggSnYu/AD0Yqm8vVO0kWlun1rFbdO+QUZKyVr/OPUjQSw4SRh4qsTKf/+eFoWTjplFvd1WCBZzS/WRenxIwR00KkczHSJro763+wYcwKieb4eKRxaQoQvoFgVjLBULXAjH4eKoKTVNtMXAvPP9aMy2SLgsJNtMb9ArfziAiblQynq7UIfLnN3VclzPeiWrqtzjyOp6CPUXnL0lVPTvbLe8sUteBsJZwlL6K4i+Y0lf3ryqnmQgC21yW4Dzu+kwk8FVT2MgWkCwiZd8gQ/+uJzrJFyMfUOBIklOBfuUENIJUhAB Generated-by-Nova
