Help Center/ Blockchain Service/ User Guide/ Enhanced Hyperledger Fabric BCS Management/ Consortium Management/ Notification Management
Updated on 2023-01-16 GMT+08:00
When another tenant invites you to join a consortium blockchain, you will receive an invitation notification. Then, you can view the invitation on the Notification Management page.
- To accept the invitation, click View Details in the Operation column of the notification list, select a BCS instance and organization, and click Accept.
- To decline the invitation, click View Details in the Operation column of the notification list, and click Decline.
- To delete a notification, click Delete Notification in the Operation column of the notification list
- To postpone the processing of an invitation, click View Details in the Operation column of the notification list, and click Process Later.
- Click Create Instance and use the new BCS instance to join the channel.
- Notification statuses include:
- Unprocessed: You have not processed the invitation notification. You can click View Details to accept or decline the invitation.
- Finished: You have accepted the invitation to join the consortium blockchain.
- Canceled: The inviting party has deleted the instance before you accept the invitation. You cannot join the consortium blockchain.
- Declined: You have declined the invitation to join the consortium blockchain.
- Quit: You have accepted the invitation and joined the consortium blockchain but later quit the consortium.
- Dismissed: The inviting party has deleted the instance after you joined the consortium blockchain. As a result, the blockchain is dismissed.
- Frozen: The inviting party's account is frozen.
- Upgraded: An instance in the consortium blockchain has been upgraded after you join the blockchain.
Parent topic: Consortium Management
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
