Updated on 2024-07-04 GMT+08:00
Column Alias
Function
This statement is used to specify an alias for a column.
Syntax
1 | SELECT attr_expr [AS] alias, attr_expr [AS] alias, ... FROM table_reference; |
Keyword
- alias: gives an alias for the attr_expr field.
- AS: Whether to add AS does not affect the result.
Precautions
- The to-be-queried table must exist. Otherwise, an error is reported.
- The alias must be specified before execution of the statement. Otherwise, an error is reported. You are advised to specify a unique alias.
Example
Run SELECT name AS n FROM simple_table WHERE score > 90 to obtain the subquery result. The alias n for name can be used by external SELECT statement.
1 | SELECT n FROM (SELECT name AS n FROM simple_table WHERE score > 90) m WHERE n = "xiaoming"; |
Parent topic: Alias
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
