Updated on 2024-07-04 GMT+08:00
Table Alias
Function
This statement is used to specify an alias for a table or the subquery result.
Syntax
        SELECT attr_expr_list FROM table_reference [AS] alias;  |
Keyword
- table_reference: Can be a table, view, or subquery.
 - As: Is used to connect to table_reference and alias. Whether this keyword is added or not does not affect the command execution result.
Precautions
- The to-be-queried table must exist. Otherwise, an error is reported.
 - The alias must be specified before execution of the statement. Otherwise, an error is reported. You are advised to specify a unique alias.
Example
- To specify alias n for table simple_table and visit the name field in table simple_table by using n.name, run the following statement:
1SELECT n.score FROM simple_table n WHERE n.name = "leilei";
 - To specify alias m for the subquery result and return all the query results using SELECT * FROM m, run the following statement:
1SELECT * FROM (SELECT * FROM simple_table WHERE score > 90) AS m;
   Parent topic: Alias
